Yes i cleaned the connector as best i could and tried starting no difference.probably gonna buy a new sensor anywayChuck W wrote: 07 Jan 2023, 09:50Fix this. Any corrosion can cause a bad signal to the ECU. An open , or high resistance ECT circuit will cause a no start, especially when it's cold.AndreasJJ wrote: 07 Jan 2023, 07:36
Checked the ect sensor now..and there was one damaged wire and alot of corrosion
It doesn't cause no spark, it over-fuels, to the point of flooding.
I bet you'll find the CEL bulb pulled, instead of just burnt out.
But still the what can cause the no spark any pinouts i should read at the ecu?..Any ground wires? But i also read somewhere If it is a ecu ground the relay on the fan shroud wouldn’t work but u don’t know how true that is but worth a mention..something is not signaling right
