I only ever see these wires going into harnesses, never dug into these. But seems like they use a common sensor ground.
Looked up ecu pin A18, says "Signal ground sensor (measure with neg. batt.)"
have you measured resistance
- sensor wire ground pin on sensor side to ground?
- sensor wire ground pin ecu connector to ground?
If both are ok you should also get continuity, so one of these should be not ok in your case, is what I think.
ECT sensor wiring 1995 850 N/A Fenix 5.2
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
850 T5-R '95 auto
- Kokonradus
- Year and Model: 1995 850 10v GLE
- Has thanked: 14 times
Maybe it´s a stupid question, but how works the numbering of ECU pins? I could not find the pin that has continuity to ECT sensor ground on connector. I am sure only of those pins on the picture. Their numbers on schema are 31 and 32. Have no idea what is the numbering system and which pin or pins ,,should,, be the sensor ground 18.
1995 Volvo 850 2,0 10v NA - Wagon
1996 Volvo 850 2,5 20v NA - Wagon
1992 Škoda Forman 1,3 Carburetor
2004 Volvo Xc70 D5 AWD (Sold)
1998 Škoda Felicia 1,9D LAURINA (Sold)
hausmeister
I think that is the best pic I have, maybe someone else has some more info on the connectors. Note its from a me4.4, but shouldn't matter for numbering.
850 T5-R '95 auto
- Kokonradus
PROBLEM SOLVED
Bad ECT connector contact. Replaced with new connector and problems are gone.
- 398 Views
- 2620 Views
Last post by Chuck W
- 11 Replies
- 3242 Views
Last post by precopster
- 35 Replies
- 2180 Views
Last post by MotorTheresa
- 11 Replies
- 1434 Views
Last post by P80GLT
