96 855 no voltage on cam plug and other places.. Topic is solved
AndreasJJ
Year and Model: Volvo 855r 1996
Post by AndreasJJ »
Any electrical geniuses here?
Did some meassuring once again
No spark problem also no CEL on dash when ignition is on (bulb maybe burnt) and no power on A26 and A27 on ecu pins but got 12v on A12 when ignition is on
Blue wire on ignition coil 12v drops to 10 when cranking (should be waayyy Lower apparently)
Red wire on ignition coil 12v as it should
And i get no voltage on b11 on the ecu pin while cranking (should be 3-4v)
From engine harness Pin 1 on CAM sensor is 0 ohms (as it should)
Pin 2 on cam sensor 0 (should be 5v)
Pin 3 on cam sensor 12v (as it should)
Has thanked: 2198 times
Been thanked: 1851 times
Being a Euro spec car, does it have an immobiliser and chipped key in 96?
Neil
AndreasJJ
Post by AndreasJJ »
scot850 wrote: 15 Jan 2023, 10:10 Being a Euro spec car, does it have an immobiliser and chipped key in 96?
Neil
The immobilizer is long gone (bypassed) and should not cause these issues either..the car would start and then die not cut spark just fuel :)
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Main fuel injection relay(grey one) on fan shroud?
Not having lambda light with ignition in posII along with all other lights means that ecu have no power.
Fuse no.1 ok?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
