2001 V70T5
The driver's side seat heater does not work, although the passenger side does. It did not work with the original seats, nor with the replacement seats. The on / off - back / seat button lights up, and the fuse is good. So my guess is there is no power getting to the seat heater. but I don't know which wire is the 12v. . I don't have a pin out of the connector and I can't find it on the net, so if someone has it, I would appreciate sending it to me.
Ideas on where to look? Maybe the on / off button is bad?
PS - does power go to the seat heater connector with key in II position? Or does the engine have to be running?
seat heater not working
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
thanks - I can snag a button at the parts yard. Won't take much time to swap in a replacement button. Both indicator lights on the button light up, BTW
Neither seat back nor seat bottom heat coils work. I got a wiring manual but it's not for my car - the one I have shows separate L / R seat heat fuses at 7 and 8, but mine has a single 25A fuse for both front seats. I found the power connector for the seat - assuming it is one power source for the seat motors and the seat heaters. And there is power there. So my idea was to find the wires at the seat that enable seat back or seat bottom and jump the connectors to see if the heat comes on. But I need a diagram for that.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
azureblue
I see from a 2005 wiring diagram that there is a relay panel to the right of the steering column, behind the kick panel. I am assuming that the dash control buttons control a pair of relays (seat back and seat bottom) so I want to check that.
I'm having a time finding the correct service manual for my car - could someone tell me if the 05 is applicable? Or where to find the right service manual?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
another reason to get vida set up on a laptop. You could probably control the heaters from Vida, that bypasses the button.azureblue wrote: 16 Jan 2023, 10:47 I see from a 2005 wiring diagram that there is a relay panel to the right of the steering column, behind the kick panel. I am assuming that the dash control buttons control a pair of relays (seat back and seat bottom) so I want to check that.
Try this,
https://www.manualslib.com/manual/533732/Volvo-V70.html
azureblue
Thanks but this manual is for a 2005... at least it says so at the bottom of the pages.
And, yeah, I need to set up VIDA.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- Has thanked: 1611 times
- Been thanked: 4074 times
Big changes from 2001 to 2005 electrical. Get VIDA and the correct wiring diagram
azureblue
I got VIDA, but it's still not set up. I don't have a P2 service manual - I can't find one on the net, but I'm still looking.
At this point logic would point to a failed switch or relay. Since the 12v socket on the dash isn't working, and I want to replace it with a USB outlet, I will probably wait and do both jobs when I have the panel off.. But I can't find where the relay for the seat heaters is. If I can find it, at least I can check to see if it is clicking, which would tell me a lot more..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
The 2001 is an early CANBUS car so it doesn’t use traditional relays. The Sest Heater Nodules 9/12 9/13 will be triggered by CCM and CEM inputs and feeds. You could hit the button and look for 12 volts at the connector under seat to see if it is just a burnt out heating element
- jonesg
vida is the manual.azureblue wrote: 17 Jan 2023, 07:22 I got VIDA, but it's still not set up. I don't have a P2 service manual - I can't find one on the net, but I'm still looking.
- 1538 Views
Last post by Ozark Lee
- 357 Views
Last post by Caffeind
- 1277 Views
- 561 Views
Last post by Stingray06
- 1654 Views
Last post by lummert
