Adding a Coolant Level Sensor!!
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Re: Adding a Coolant Level Sensor!!
Post by kcodyjr »
Depends on how the temperature sensor acts normally. Is overtemp represented by a high resistance or a low resistance?
If overtemp is a high resistance (trending toward an open circuit) then I'd wire the coolant level sensor with it in series, and use a coolant sensor that opens the circuit when the level drops too low.
If overtemp is a low resistance (trending toward a short circuit) then I'd wire the coolant level sensor with it in parallel, and use a coolant sensor that closes the circuit when the level drops too low.
That way, the computer will read a loss-of-coolant event as an immediate overheat.
5 others that came and went
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I'd google see if reservoirs with sensor from other vehicles are small enough to fit the S40, even from other brands, Mazda, Toyota, might be lucky
kcodyjr
Post by kcodyjr »
You know, another option is to wire an open-on-low-coolant sensor in series with the fuel pump relay (control side).
Immobilizing the vehicle if it loses coolant isn't an entirely insane thing to do.
MadeInJapan
Been thanked: 35 times
Post by MadeInJapan »
Great ideas!! The sensor I got can either be set to open or close depending on if I turn the float around or not. I looked but there is not much room in our reservoir tanks for much in regards to third party (other maker's float sensors)...the small tank is separated into 6 chambers with walls in the sides. Straight up and down near the filler cap seems the only logical placement. Keep posting everyone!!
Has thanked: 1505 times
Been thanked: 3818 times
Well..if you want us to follow at least show pictures of the boat...
How about tying it into a bulb or interior light to give a visual cue?
It is amazing this series uses overheat as the low coolant warning...ouch!
Radio Shavk would have a buzzer that would work here
MadeInJapan
Yes, I have considered a buzzer...I'm leaning towards that.
I'd use a light except it was a real bitch to get a thin, smooth boost lines into the cabin for my boost gauge...I can't imagine fishing wires through the thick rubber piece that I had to poke through- it seals up like the rubber port of a medicine bottle as soon as you pull out whatever it is you poke into it.
Boat pictures? Hmmm- let me get the boat in the water (hopefully this weekend) and I'll snap a shot!
beigg
Year and Model: 850 97
Post by beigg »
ugh smh 850 Turbo fridge
MadeInJapan
beigg, thanks for your posted links. I really cannot use a different tank as there is no room for much of a tank to begin with. I think I've figured things out but I've gotten lazy and so have not worked on this since last year. When it warms up, I'll cut the actual hole in the bottom of the tank already in the care and give it a go. I just don't want any leaks or else this will be self-defeating!!! But...it looks like the only place I can get a float sensor to sit is from an opening in the bottom of the tank (like my pictures show from page 1 of this thread).
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
MadeInJapan curious if you ever went though with this sensor? As I’m digging into my newly acquired C70 thinking about how to alert low coolant. Step one for me will be replacing the octopus hose.
08 C702.5T (sold)
The non-Swedes:
Richard99
Year and Model: 2000 V70XC
Has thanked: 26 times
Been thanked: 22 times
Post by Richard99 »
There is a video by Robert DIY on how to do this
Eric
1998 Volvo V70 - rear-ended and totaled
2000 Volvo V70XC
2007 Volvo V50 T5 AWD M66
