I never got the fixation on the FCP return thing. ChitownV, you seem to use FCP a lot and you always bring up the return capability "for any issue" in your posts on Swedespeed. IIRC, you did a coolant service on your 3.2 using their warranty return mechanism, were the parts broken outright or you just wanted to replace them under a scheduled proactive maintenance effort?
Do you send them your used oil and filters?
TPMS Sensors Topic is solved
chitownV
- Year and Model: 2008 XC90 3.2
- Has thanked: 15 times
- Been thanked: 40 times
Yes you can, even original Volvo parts. You can read their policy on their website. They also posted pics of returns on their website.
I think nowadays the return gives a credit rather than refund, but there’s always more maintenance items to buy. To make it worth while, groups parts into one shipment.
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
So you're basically supporting the entirety of your vehicle maintenance lifecycle by buying a single set of parts and taking advantage of the part supplier's open warranty to support periodic replacement whether the returned component has failed or not. Interesting approach.
chitownV
Yup. I get good life out of the parts and I believe that’s similar to how FCP states their policy (life of the part) because parts like filters, spark plugs, belts, and oil should be replaced before failure. That’s where I noticed they try keep their parts catalogue with quality parts. Sometimes they have lesser quality, but that’s usually due to high cost of an original or supply issues of the better aftermarket brand.
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
Here is a quick find for keyword "TPMS":
https://www.fcpeuro.com/Volvo-parts/XC9 ... ds=TPMS%20
...possible direction of wheel upgrade
- tpms kit: 315Mhz
rim: 20" x 8.5"
wheel offset: +35
hub bore ring: 67.1 <-> 73.1
bolt pattern: 5x108
tire: 265/45R20:
xHeart
...being on the course of wheel upgrade; the local wheel & tire package guys are throwing-in a set of Purple Maxx sensor (315-443mHz); pre-programed which activates with drive-cycle aka Relearn - your thought?ggleavitt wrote: 19 Jan 2023, 17:40
You have VIDA and if you have access to a TPMS tool then get a sensor, open up the UEM window in VIDA, do a trigger and give it a try. If you see a serial number in the TPMS window in VIDA then you're good. The VDO SE10006 for sure will work, I prefer the metal stems myself so went with the SE10003 when it was $25 each. But I know there are tons more out there that'll work.
- ggleavitt
No reason why not, the site- https://www.max-sensor.com/s/MAX-SENSOR ... 02022.xlsx has a vehicle coverage list which says it will (notes both 315 and 433 as applicable).
chitownV
Ironically, this was asked about in a thread not too long ago. A link to look up the frequencies is also in the earlier thread.
viewtopic.php?t=101548
xHeart
The guy says, Purple Maxx is relatively advanced product in TPMS class. I'm working on my upgrade; meanwhile...
A drive with VIDA/DiCE -- after a RESET, it started to pull different IDs and corresponding pressure data at each box (not sure about wheel). The first three, 842-, remained constant, but the last four jumped from box to box (wheel to wheel); I can say with certainty, there were 4 different numbers present at one time. It is confusing at this first take.
FWIW: my laptop was powered by a 180W 12V to 110V inverter connected to cigarette lighter port in cargo area.
chitownV
It does that and it’s more of a how frequent and consistent the ID #s are over time. I was getting IDs from other cars when I was driving and looking at VIDA. As long as the dash light turns off, then you are good.
The guys at the shop are selling, lol. Maybe they are better for them as they have the 2 common frequencies. But I it sounds like it will be good enough for your ownership of the XC90.
- 1344 Views
Last post by Georgeandkira
- 918 Views
Last post by mlanctot
- 11 Replies
- 3697 Views
Last post by DavidE7
- 11711 Views
Last post by packetfire
- 958 Views
