Rubber Dust Shield between the axle shaft and hub bearing?
This topic is in the MVS Volvo Repair Database » Kick Panel Broken Tabs Fix
Has thanked: 2215 times
Been thanked: 1853 times
It is possible if the seal does not get seated properly or the old seal breaks up when re-fitting and blocks the abs sensor reading correctly. The sensor reads the grooves in the toothed wheel. If a piece gets in there or there is a build up of crud gets dislodged into the 'teeth' it will throw a wobbly.
I would fit new seals and carefully make sure all the rust is cleared out of the teeth with wire brushing before fitting the new seals.
ronmeneses
Year and Model: 2005 V70
Post by ronmeneses »
Yeah, thanks. I was expecting that would have to be my next step. Not looking forward to repeating the work, haha.
I hear you. I have the RH axle seal to do on our son's 06 XC70. Really looking forward to that............!
