a3inverter
- Year and Model: 2006 V70
- Been thanked: 9 times
As I was in the car fixin' mood (resolved a bunch of items on our Honda Odyssey yesterday) I tested my evap canister purge valve. No clicking so maybe this is the root cause of my persistent P0442 (EVAP Control System Leak Detected Small Leak)? FCP has 'em reasonably priced. Also noticed that the rubber line that goes from the intake manifold to the PCV device beneath the manifold has cracks in it. I think I just used a piece of fuel injection rated hose for that when I replace the PCV canister about 3 years ago.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
This morning it was 11 below zero F here. I'd rather just stay inside. But my wife needed to go somewhere on her day off, and Betty the Volvo wouldn't start. I eskimo'd up, dragged an extension cord to the curb, and hooked up the HF charger. Ran a couple three hours, said it was "repaired." I checked with a multimeter at the engine compartment hot, and it read 12.7 something volts. Not great, maybe ok if it's warmer. It only get short trips a mile to work or groceries, so that isn't good for it, plus the cold we've had.
I drove her to the store just in case, topped up gas, started right back up, left it running until she was done. I should dig into the trunk to see when we bought this one.
-11 F will bring any weak battery to its knees. If it’s over 5vyears old in those climates, it’s time* to replace it, especially if it’s a short trip car.
* Says he nursing his 9 year old P2 battery through winter
Herb Goltz
- Year and Model: 04& 06 XC70, '12 s60
- Has thanked: 7 times
- Been thanked: 5 times
Just replaced the 2015 vintage battery in my 2004! Turns out you can fit a group 49 battery in these cars-- 1100 cold cranking amps should do the trick, even here in the Great White North...
2012 s60 t5
2006 XC70
2004 XC70
2006 XC70
2004 XC70
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Has anyone tried optima batteries in these cars?
IlikemyXC70
- Year and Model: 2004 XC70
- Has thanked: 6 times
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
I would recommend a welder after mechanic finishes your repair.IlikemyXC70 wrote: 01 Feb 2023, 09:44 Had fun at the beach.
I also broke itCame down a steep dune too fast and broke the radiator, also bent in intercooler and the a/c radiator, so they're probably bad. I'm out of town in central coastal California. Can anyone recommend a mechanic around these parts?
Was motivated twice to weld this thing. First time after crashing in wilderness with no cell coverage (luckily the subframe took most of the hit, the radiators were only bent). Second time hit a bear way up north in Quebec. Again, no cell coverage, no traffic on weekends, closest settlement is 200 miles away.
IlikemyXC70
That's awesome. I was thinking the same thing, basically a frame with a screen like yours, or four thick tubes curving down in front, almost like a football helmet face guard.
I found a shop who can fix me up. Should be on the road again soon, but will probably stick to the coast for now
vtl wrote: 01 Feb 2023, 10:04
