12.4-ish volts, same as battery (well a little less) with car off. It's not putting out any charge. FWIW, also checked continuity on Big Red Fatty (main + cable) from alt. to battery, it's 0.00 ohms
Alternator question
MissouriJim
- Year and Model: 2000 S70
- Been thanked: 4 times
MissouriJim
I have pulled the alternator, and removed the regulator.
Can anyone tell me which points on the reg. should have continuity? Again, the exciter pin doesn't seem to ever reach ground, as the dash light never comes on, but does come on when I directly ground the exciter wire.
TIA!
TIA!
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
What shape are the brushes in? Look for blown traces / components on the board. These voltage regs are kind of hard to test. They either work or they don't.MissouriJim wrote: 06 Feb 2023, 15:45 I have pulled the alternator, and removed the regulator.
TIA!
Always check FCP EuroMissouriJim wrote: 06 Feb 2023, 13:26Can you advise where I can source this? The only inexpensive ones were Chinese-made on Ebay from relatively unknown sellers.WhatAmIDoing wrote: 06 Feb 2023, 11:10 I would just order a new voltage regulator, ~$40. Reduced the risk of having to do it again.
IPDUSA has them for around $200
Knows enough to be dangerous
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
The internal regulator doesn't respond like old school units.
Internal means just what it sounds like. Similar to a GM 3-wire,
all of the magic happens inside the alternator. It just monitors
system voltage and excites the field when needed.
IIRC, it sees system voltage through the little R/W wire on the
alternator and all that grounding it does is provide a ground to
the light in the dash like a dead alternator would and lights it up.
Since the regulator is looking for positive power on that lead,
I'm not sure if grounding it is a good idea.
The diagram displaying this connection is attached:
And being a self contained unit, I'm not sure what to advise
as far as testing it. If it isn't producing 13.8 vdc or better and
the brushes look good, replacement is probably your best move.
Many believe that OEM Bosch is the best option for this.
MissouriJim
@ BEJinFbk Thank you - again, I only grounded it to prove the Charge dash light actually works and wasn't burnt out. A little confused why Volvo would rely on the actual circuit rather than a secondary test circuit for such things, but alas, such pondering is of little use
@WhatAmIDoing The brushes look burnt, if that makes any sense. One is substantially shorter than the other. They look worn - as they should, after 400K miles.
Anyhow, thanks for all the help, I found the unit on FCP for much less ~ should arrive next week. I think I'll visit the yard anyway this weekend & grab an extra just in case, plus that power steering pump. If it's not needed, I can always re-sell.
FWIW, and it's probably mentioned elsewhere, but removing the upper radiator hose makes all the difference when yoinking the Alternator up and out. Yes it's a bit of an irritant to use the catch-pan and top off the coolant, but it's better than ruining hoses and wires.
I'll post back here with final results.
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
The rest of the alt is probably fine, just the brushes on the regulator are worn out. I've actually successfully replaced the brushes on a couple of alternators (The current one in use in the wife's car is running a "re-brushed" regulator.MissouriJim wrote: 07 Feb 2023, 05:27 The brushes look burnt, if that makes any sense. One is substantially shorter than the other. They look worn - as they should, after 400K miles.
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
I would install a new alternator, not much more than only a voltage regulator and it's a wear item. When ours failed, the charging light also did not come on. One day it was just 'over and out'. X2 on ensuring all cables are tight including ground strap to the engine and chassis.
MissouriJim
I picked up a salvage alternator over the weekend & all's good. Key on, I get my battery dash light, and started up it's passing 14.4v across the positive terminal now.
I also ordered the regulator and confirmed the old one is bad, as the new one (and the salvage alt.) read 10 mega ohms across the exciter pin - to - positive terminal but the bad one reads infinity (open circuit.) Not to say they'd all fail this way, but mine did.
So, I'm all set, plus a spare alternator to keep in the trunk because we all know they usually decide to go out on long road trips...
- Has thanked: 2210 times
Thanks for closing this out for us! Glad you found the solution.
- 20 Replies
- 7620 Views
Last post by tonie
- 556 Views
Last post by E Showell
- 932 Views
Last post by mtd240
- 823 Views
Last post by erikv11
- 10 Replies
- 3121 Views
Last post by hausmeister
