bulkhead / firwall insulation
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Post by azureblue »
My firewall insulation is mostly gone - besides the Volvo original, is there something better that would work?
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
Try furnace insulation, some are sticky backed. They use it to line the walls of oil furnaces in home heating systems.
Home depot might also have a type that has foil faced on one side to stop it from soaking up oil.
You don't need the special glue, regular contact cement will work,
buy a quart can and slop it on with a cheap brush. (not the 3M spray type).
Heres a ceramic sheet type.
https://www.amazon.com/Kaowool-Ceramic- ... NBWF3?th=1
azureblue
Post by azureblue »
thanks - never thought of that ----
I was looking at heat shield sound mat, but realized I would have to custom cut it. And that means finding a pattern to cut it to.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Been thanked: 504 times
Post by cn90 »
Whatever you use, cut a small piece and bring it outside and test with fire, it should not be flammable.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Don't use glue or self-adhesive pads. Firewall is directly above the downpipe, it gets tremendously hot, most glues will turn into goo. Fix it on firewall mechanically, like the original insulation does.
Also firewall has some nice sound dampening and thermal insulation at the other side. If you add more sound dampening, you won't hear your five cylinders, which makes no point ;)
azureblue
Post by azureblue »
it's on the other side of the firewall behind the motor - almost all of the insulation is torn out
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
vtl
Post by vtl »
azureblue wrote: 08 Feb 2023, 09:57 it's on the other side of the firewall behind the motor - almost all of the insulation is torn out
Yes, I understand. I just said there's no need in making it even more soundproof (than it was from the factory). And don't use glue.
azureblue
Post by azureblue »
I would just like the make it factor spec at least. And to reduce heat. It mostly bare metal now. Previous owner let it sit, and critters tore out the insulation
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Find a good original insulation mat at a salvage yard? Or at least one to use as a pattern.
volvolougnut
azureblue
Post by azureblue »
I was hoping to find a pattern pdf or something - Volvo has it in 3 pieces but I can't find picture I can get a pattern from.. The mats at the yard seem to all be glued on pretty good.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
