My S80 Floor Is Wet On Passenger Side
junlinshao
- Year and Model: 2004 S80
recently I found there is a lot of water on passage floor, then i started to clean, later, i notice there is water under rear seat, i remove rear seat, the sponge is completed in water. what i do is i use wire to clean up sunroof hose, remove passage seat and make everything dry. however, it does not help, the water still enter in when it is raining. anybody has any clue? thank you.
- Has thanked: 987 times
- Been thanked: 1076 times
Test the sun roof drain with the front carpet pulled up or removed. Pour water in the sunroof corner drains (all corners may have a drain hole) and see if the water still enters the foot well. Check at the firewall on both sides that the drain tubes are all connected and not damaged. They should all flow to the ground below the firewall. If you do not get a good flow to the ground you may still have a clog in the drain hoses. Clean the tubes again with a wire or string weeder line.
There may also be water entering from the cowl area if the outside air vent seal leaks. Check this by pouring water into the cowl opening below the windshield. It should also drain to the ground.
There have been a lot of other posts about these leaks.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
This is a good check. I recently had to seal up the molding under cowl on my 05 XC90. With lots of ice it was allowing LOTS of water inside the cabin and straight past blower motor.volvolugnut wrote: 08 Feb 2023, 12:29 There may also be water entering from the cowl area if the outside air vent seal leaks. Check this by pouring water into the cowl opening below the windshield. It should also drain to the ground.
I used some RTV to seal the plastic riser up to prevent water leaking in, even without ice there (it’s on the far passenger side). If you remove the clips at the front of the plastic you may be able to pull up the front windshield cowling without removing the wipers, I was able to.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
junlinshao
I spray water on the roof, and notice water enter the rear seat, for sure, water is coming from roof, i have ordered roof seal rubber and see if it can be fixed
Do you have a sunroof?
it can also be a leak coming from the blower motor housing, there is a passage under the hood, close to the drain on the passenger side,the seal that keep the water out get brittle, and can cause water going to the passenger side, i experience that on my s80, easy fix, rtv.
- 23 Replies
- 4920 Views
Last post by rguzz
- 1182 Views
Last post by MoVolvos
- 615 Views
- 1024 Views
Last post by Skymongrel
- 2184 Views
Last post by jtmccue
