#7 fuse blown, no brake lights - 1987 245 DL
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
myspv
Year and Model:
Post by myspv »
#7 fuse (stop/brake lights) keeps blowing. so, no brake lights.
before i dig in i thought i would see if this is a common problem, maybe particular to the wagons(estates).
if no one has any ideas i think the first place i will check is for frayed wiring insulation around the hinge for the hatch. i can't think of other wires that would get stressed so much. i'll let you know what i find.
(aside: i know i should always check the easy thing first, but for some reason the first place i headed was to check for continuity at the switch behind the brake pedal. at least i know that part is fine.)
(approx. 265,000 miles)
