cylinder 5 cuts out when it gets warm
papascrappy
- Year and Model: 2008 V 70
Does anyone have an idea what would cause a single cylinder to misfire only once it gets warm? When I first start the car, it runs great, but after 10 or so minutes number 5 cylinder starts cutting out. I have changed the plug and the coil. Had a water leak a few weeks back, and the steering wheel lock gave me trouble, but that is all the problems I have had.
- Has thanked: 987 times
- Been thanked: 1075 times
Coils can fail when they get hot. Do you have coil 5 fault code?
Try swapping coil 5 to another cylinder and see if the fault moves.
SORRY! I did not read your post well before making comments. Check coil feed wires and grounds for good contact. Is the coil boot cut or coil to plug contact bad?
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Can you post a picture of the sparkplug that you removed?
It is possible that you have an injector problem.
You didn't say which engine but I will assume that a 2008 V70 is the 3.2 6 Cylinder.
What is the fuel trim for bank 2 (LTFT and STFT)?
Other things to check
1. Check the wiring to the ignition coil for #5 (does the latch work?)
2. Check the PCV to see if it is broken (engine at idle remove the oil fill cap and you should have a very slight vacuum)
3. Check the wiring for the #5 injector (does the latch work?)
Good luck
Paul
Good luck
Paul
- 11 Replies
- 3527 Views
Last post by bmdubya1198
- 447 Views
- 15 Replies
- 4108 Views
Last post by dikidera
- 3540 Views
Last post by 93ForMe
- 871 Views
Last post by erikv11
