Hello there,
One of the gas station attendants banged on the gas door hatch and broke one of the pins that holds the hinge on the car body.
It's not the hinge itself that broke, just the pin that holds it to the body of the car near the gas cap.
Is that pin a rivet or a machine screw or something else?
Is there some way to fix this, and if so, what would be the best fix?
Thanks much for any ideas especially if you've had to do this before too.
Broken Gas Door Hinge Fix
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
From what I've seen it's something like a plastic peg.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 2205 times
It is an integral plastic peg. The only way I have found to remove it when replacing is to break the whole thing off from what I recall. Others may disagree. Volvo uses a lot of push pins that flare out the plastic legs on the rear of the panel like a drywall anchor. Some you can depress the pin and it releases the peg and you can wiggle them out with a small flat screwdriver. I am fairly certain that is not possible with the fuel flap hinge. Options are to buy a replacement, or consider drilling it large enough to use a rivet, which has the chances of damaging the paint.
If you look at IPD's web page you can see the pins. I now recall that the only way they come off is to push the pin right through which usually loses it down behind the fender liner.
https://www.ipdusa.com/products/6174/Fu ... gJJiPD_BwE
- MrAl
scot850 wrote: 19 Feb 2023, 09:28 It is an integral plastic peg. The only way I have found to remove it when replacing is to break the whole thing off from what I recall. Others may disagree. Volvo uses a lot of push pins that flare out the plastic legs on the rear of the panel like a drywall anchor. Some you can depress the pin and it releases the peg and you can wiggle them out with a small flat screwdriver. I am fairly certain that is not possible with the fuel flap hinge. Options are to buy a replacement, or consider drilling it large enough to use a rivet, which has the chances of damaging the paint.
Oh ok. Well here's the state that it is in now. The pin broke off from the car body and the part in the car body must have fallen inside the body cavity because the hole is wide open. So the hole in the body is open.
I think the problem is that part of the pin is still inside the hinge. That's the part i would have to get out i guess to fix it.
Sound like anything you know about?
Thanks Neil.
To save the door you might want to remove it completely so as not to lose it. Part is not too horrendous, but shipping makes it more so.
You will need a long punch or a small round nail to push the pin through.
454cid
I've seen people on Youtube pull the pins, but my concern would be if the part on the hinge that flares out is now broken off. It's possible a nylon screw and nut would work to fix it, but it might not fit well and consequently not locate the hinge all that well. I would not use anything too strong as it would likely hurt the sheetmetal if the door were to hang up on something.
I think the best bet would be to replace the hinge. I would go OEM Volvo. I tried an aftermarket latch and it was a waste of time/money. When I bought the Volvo part it fit and worked perfectly. I don't normally say "OEM Volvo only", but in this case I don't think going aftermarket is a good idea.
Edit: Make sure you order the right hinge for the year... my 96 and 99 use different hinges because the fuel door operation is a bit different.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Correct, 850 and V/S70 have different hinges, latches and fuel flap actuators.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.MrAl wrote: 19 Feb 2023, 08:22 Hello there,
May be similar enough. As mentioned it would no longer be a break away, perhaps as Volvo intended design.
viewtopic.php?start=20&t=100706&sid=f69 ... 582b9142dc
- MrAl
MoVolvos wrote: 19 Feb 2023, 12:31.MrAl wrote: 19 Feb 2023, 08:22 Hello there,
Hi,
Thanks that's exactly what i would like to do. I do have a question though. I see those nice two phillips head screws but what are they anchoring into? The holes behind the holes in the plastic where the screws go through on the hinge are about twice as big as the holes in the plastic hinge. So the holes in the sheet metal body are bigger than the holes in the hinge. That means i cant put a screw that fits into the existing holes in the hinge and expect them to anchor into the sheet metal.
So how are you getting the screws to anchor into the sheet metal directly behind the plastic hinge mounting part?
Also, what is the red tubing for? I see you used a tie wrap too to hole the spring thing in the right place. That's a problem with mine too.
Thanks.
- 1019 Views
Last post by E Showell
- 753 Views
Last post by Templin113
- 653 Views
Last post by erikv11
- 9 Replies
- 3110 Views
- 1536 Views
Last post by combatkarl
