Had this issue with a 98 manual climate control system. Solved it by resoldering the pin connectors which restored defrost, AC activation, and other controls.
yanga001
- Has thanked: 59 times
- Been thanked: 110 times
2008 S60 2.5T Auto (Sold)
yanga001
Figured out i need to adjust my brake switch to restore my cruise control. I had tried what others suggested to pull back on the brake pedal and set the cruise and noted it would not activate or stay activated. Yesterday a held the brake back with my left foot, set the cruise and continue to hold it and voila it went into cruise mode. Will report if its repaired after fixing the switch.
Also got all the foglights and headlights activated and aimed. Had fun plowing through about 15-20 cm's of snow during a snowstorm but it all held together.
Last thing I would say is that PB blaster on the steering knuckle is like black magic. My steering went from near locked up to loose again. Applied it to the steering knuckle located to the right of the exhaust manifold when looking from the front and it significantly loosened up the steering.
- Has thanked: 304 times
- Been thanked: 517 times
Don't ya love when that happens?
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
This one is ECC. Its changed output on me only once, since I bought it. I can't pull codes on it either since it's a 99 as 850obd2 wont talk to it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- CIK7
- Has thanked: 318 times
- Been thanked: 86 times
I reinstated the insurance on my red v70. Then I spent about 2 hours working on it. I hooked up a 2nd horn (factory) to the wolo low tone. Sounds better. I installed the factory fuel injector cover and the factory Throttle body cover. I installed the factory AI hose from air box to core support. I rewired the power source for the afm AUX unit because it has slipped out twice. I uninstalled the 99 donor wheel and airbag and reinstalled the 960 wheel and airbag. Horn works! I secured the driver side door card with one of those white door snaps. It's been flapping and it made me mad a couple nights ago; it felt the blunt end of that. Installed the donor's front ashtray, gray handbrake trim piece, and the removable felt cover for the handbrake screw. Then I ripped the car down west main and east main. The engine mounts are noisy.
Might have a big update tomorrow.
- Has thanked: 1497 times
- Been thanked: 3810 times
Missed my 10 year MVS anniversary last week. Generally I won’t join any club that will have me as a member.
- CIK7
Congrats! I think I joined in January 2019. This makes 4 years.
- Has thanked: 1836 times
- Been thanked: 1709 times
It has only been 10 years Abscate?? Just seems like a lot more.............
Congrats on the anniversary, and many thanks for your aid in supporting MVS.
Wow... even I'm coming up on 10 years here. That's crazy to believe.
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
Need a mustache and cigar to make that work.
