Even in our weather I have not had too much issue undoing these bolts unless someone has been in there before and rounded them. /i have a large set of Vice grips that have helped a few times where the bolt was damaged. Maybe a Torx bit might also work on damaged bolts?
Prop-shafts are hard to find and if the front bearing and support bearing are good then is has a decent value.
upDATE5: 99 s70 silver awd turbo auto PARTS fs (bulk too), Antlers OK Topic is solved
- Has thanked: 2203 times
- Been thanked: 4068 times
Please don’t cut that driveshaft.
Use an Irwin extractor or , worst case, cut the heads off the bolts to free the driveshaft
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
I updated OP with prices.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
A mere 8 hours previously...abscate wrote: 24 Feb 2023, 19:25 Please don’t cut that driveshaft.
- foggydogg
PM sent.
- CIK7
Does this look right?
I don’t like the junk stuck in the pistons. Can you clean those out?
- foggydogg
PM.
- CIK7
Imagine that those were three lazy mud daubers, a great guess from da FoggDoggabscate wrote: 26 Feb 2023, 17:08 I don’t like the junk stuck in the pistons. Can you clean those out?
- CIK7
Yo foggydoggy, here is your tracking receipt. I hope you don't mind the various plays on your nickname. Is it common for it to be foggy around you or was that just a comical idea? Either way I like it. Under my weather forecast on AccuWeather is a summary around the US; shows you're suppose to get some terrible weather. Stay warm!
