Hello all,
Has anyone removed their CEM from their V70? (2007)
I saw the video from Xemodex and am having a problem dropping the unit down.
Removed the 2 screws that hold it to the mounting frame on top but it will not drop down.(large ty rap was cut.)
I can see one of the large round mounting pins in the slotted frame but the pin slot does not match up with the frame slot. I seems like the Cem needs to be pulled at the bottom to tilt to the rear of the car so the unit can then be dropped down. Make sense? Xemodex just says drop it down.
Thanks for your help..
2007 V70 CEM removal
- Been thanked: 4071 times
Well done. If you are forcing something on a P2 disassembly, you are breaking it
- RickHaleParker
- Been thanked: 980 times
You can go through the Cowl. Remove remove the two top screws ( If they are installed, some P2 don't have them ).UV-MAN wrote: 01 Mar 2023, 12:46 Got it.
Didn't see the side bracket that needed to be moved out to release a pin.
Then reach up and press the release.
Active
Past
Past
- 9328 Views
- 27 Replies
- 28865 Views
Last post by cn90
- 10 Replies
- 10832 Views
Last post by jonesg
- 5954 Views
Last post by RickHaleParker
- 9435 Views
