2002 c70 electrical issue
lavellp7
Year and Model: 2002 c70
Post by lavellp7 »
what the issue with my dashboard it get the 888888888888888888888 and dont turn off after door shut and lock
see picture
Has thanked: 2209 times
Been thanked: 1852 times
It may be an issue with the ignition switch. Some of the displays do stay on when you switch the car off and stay on for a short while after you exit and lock the car. What the 0000 number are telling you I don't know. I think this is a badly worn electrical portion of the switch. What happens if you jiggle the ignition key in the ignition? Does it make any difference? If it does then that is your issue.
There is a small rotating switch which allows you to change the read out. Try changing the position on that as they can get oxidised when left on the same setting for a long time. I think this is unlikely in this case though.
Has thanked: 1611 times
Been thanked: 4072 times
Low voltage to the CDM. Bad battery or wiring fault
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
The first picture is when it is cold?
The second picture is when it is warmer.
The display is outside it's temperature range. How freaking cold is it there?
Active
Past
lavellp7
Post by lavellp7 »
got a new battery ........... still the same
i going too re check tomorrow
lavellp7
Post by lavellp7 »
hello rick im in atlanta it 70 outside
the second picture after i turn key off
