[SOLVED] 1999 S70 GLT, coolant temperature P0116 code, radiator fan and throttle module stay on after egnition is off Topic is solved
Has thanked: 1834 times
Been thanked: 1709 times
Re: 1999 S70 GLT, coolant temperature P0116 code, radiator fan and throttle module stay on after egnition is off
As these are just measuring the ambient temperature of the coolant when the engine is cool, I am assuming that the resistance values remain the same for when out of the car? I pulled one from the junkyard and on the bench it was showing 4,000 Ohms at +14C which seems way of based on the chart. So basically a bit of poo am I correct? Or do I need to drop it into water to check the sensor correctly?
Do the Volvo sensors have any markings on them? This one I can find no part number or logos on it so possibly aftermarket? Looking at pictures on Volvo dealer part sites, they don't seem to have any obvious markings either.
z80
Year and Model: 1999 s70
Has thanked: 3 times
Been thanked: 6 times
Post by z80 »
Ok, I've finally replaced the temperature sensor. The problem so far didn't come back. The fan doesn't start when it shouldn't and doesn't stay on when the car is off at least so far.
It looks like it's a fix at least as of now.
BTW, a rubber ring around the old thermostat has fell apart and turned into black powder as soon as I touched it. I really feel lucky I've ordered new thermostat and not just a temperature sensor.
Has thanked: 1497 times
Been thanked: 3809 times
Volvo Water Temp Sender - Genuine Volvo 9125463
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
z80 wrote: 05 Mar 2023, 20:41 Ok, I've finally replaced the temperature sensor. The problem so far didn't come back. The fan doesn't start when it shouldn't and doesn't stay on when the car is off at least so far.
I had same problem about a year ago, fan kept running.
Was the temperature sensor.
