My 03 S60 has been sitting for one year. I didn't start it in the period so the battery is obviously dead.
Today, I tried to jump start it with an external USB jump starter. But I got nothing after turning the key, no dashboard, no sound, no crank...
Now I am thinking about remove and recharge the battery and try again.
But anyone know why nothing happened with USB jump starter? It worked before with shorter sitting period, like for a winter or so.
Any tips are appreciated!
03 S60 won't JUMP START after sitting for a year.
radium2013
- Year and Model: 03 S60 AWD
- Has thanked: 3 times
- Been thanked: 504 times
The External USB jump starter is only good for minor discharge.
Let's say you are on vacation for 2 weeks, and come back, the battery voltage is 11.50V, the USB
charger can bring it up to 12V to start the car.
But if your battery is down to 6-7V or flat, the USB charger is useless.
In that case you need the 120V charger.
You may need a new battery soon.
At this time, Cost Exide H6 battery is only $119.
Most other batteries H7, H8 are now > $160 and up.
A battery that sits for a year will be dead and need replacing. It will draw Down the jump start and cause running problems even if it does start
- Has thanked: 987 times
- Been thanked: 1075 times
Modern Volvos do not like weak voltage. In the old days, a battery that would crank at a moderate speed would likely start the engine. Those days are gone. When a battery is badly discharged, like yours, it will take a serious amount of power to jump start it. Serous battery power can only flow through heavy wires.
- 987 Views
Last post by brent72
- 2219 Views
Last post by alschnertz
- 2171 Views
Last post by smacknab
- 9 Replies
- 2203 Views
Last post by clifford06
- 646 Views
Last post by Rolcon
