CIK7
Year and Model: 97 8524T & V70ST-GLT
Has thanked: 333 times
Been thanked: 87 times
Post by CIK7 »
xyna wrote: 01 Mar 2023, 09:17 Took off my door panel to discover that my window regulator motor was broken in half. Replacing it went pretty good, considering that it was my first time. Wouldn't want to do it again, though.
Has your car been in an accident? I suppose plastic could get old, but i think the window regulator is metal, isnt it? I didnt think that could crack.
09 Rav4 Ltd3.5Fwd, red, 208.5k/213k, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 305 times
Been thanked: 517 times
Post by bmdubya1198 »
I've seen things like window regulators crack, often it's with aftermarket parts that use cheaper metal. They actually deal with a lot of flex, and that can fatigue the metal over time and cause it to crack and bend.
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 131 times
Post by 454cid »
Finally changed the oil in the S70.... Mahle filter and Rotella T6 5w40.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
454cid wrote: 05 Mar 2023, 21:10 Finally changed the oil in the S70.... Mahle filter and Rotella T6 5w40.
Hi,
How do you get under the car?
454cid
Post by 454cid »
MrAl wrote: 06 Mar 2023, 03:07
Hi,
I was in my uncles heated garage, so I used a floor jack, and a small jack stand on the passenger side.... at the risk of some old oil running to the driver's side in the pan. I put the floor jack behind the wheel, where the subframe bolts to the body, and the jack stand under the subframe.
If I had been home in the driveway (too cold and wet) I would have used my plastic ramps, and driven the car up.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Hi,
If you use a pump such as the one June recommended or a manual extractor you won't need to remove the plug. Have been doing this since mid 2019. The amount of oil residue is negligible (have pulled plugs to confirm) considering there was a pan full of dirty oil and it's going to be that dirty again in a couple thousand miles.
As for the filter, lift the car slightly with a floor or OE jack and a stand under the front sub frame. You don't need to fully go under. Some card board and a plastic bag for the filter or filter housing. After loosing the filter put the plastic bag over the filter and then the rubber band should slip over the top of the bag / filter when turning to remove. I didn't think of the rubber band till after taking the photo below. Should be able to catch a large amount of oil besides not getting it all over your glove or card board.
June's link.
viewtopic.php?p=620536#p620536
Oil Extractor.png (5.23 MiB) Viewed 1109 times
05 GS430.jpg (528.18 KiB) Viewed 1109 times
Zip Lock Oil Filter.jpg (423.96 KiB) Viewed 1109 times
MrAl
Post by MrAl »
Hi,
Have you seen how the oil filter is buried in the 1998 v70? I can find a pic.
I'd be lucky to get a bag around it.
I dont like going under vehicles anymore though this car is way too heavy.
bmdubya1198
You’d be terrified by an XC90 if you think these are heavy!
Seriously, I even get nervous jacking that thing up. It’s very awkward to lift.
MoVolvos
Post by MoVolvos »
MrAl wrote: 06 Mar 2023, 21:30 Hi,
Once you loosen it, just before it starts to drip slip a bag over it and move the rubber band all the way to the top of the thin grocery bag before spinning. The S70 changed to the cartridge, not sure when in the later models and that does not spin freely as the gasket is in contact with the threads all the way down.
Has thanked: 1509 times
Been thanked: 3827 times
That baggie and rubber band trick is brilliant.
Duly appropriated.
