Hello!
While replacing the temperature sensor I've noticed several missing bolts in my car. Also a purge line comes from under the battery. I have an impression that it used to be routed differently. The car was in a transmission shop a couple of months ago. It looks like they didn't put all the bolts back.
Here is what I've found so far.
1) Splash shield used to be kept in place by two "self threaded-like" screws. Now it is attached with two plastic fasteners like the ones used to keep door panels in place. One already broke and the other one was barely in one piece. I'm so happy that the car broke and I didn't drive it much to loose splash shield while in motion.
2) An engine mount "bracket" right under the starter is supposed to be attached to the engine block with 3 screws. But now there are only two.
3) Transmission harness case on the bottom between the engine and radiator fan is flapping in the breeze. All bolts are gone.
4) Plastic nuts holding wheel well liners in place on driver's side are all gone.
5) The purge line is currently bent and attached to the sway bar with a zip tie and fed to the driver's side so that it goes to the purge valve between transmission and the battery. I have a gut feeling that it used to go down and around the radiator fan case before...
A) Would one please be so kind to let me know the part numbers so I could attach all the loose pieces together?
B) Also is there a scheme of how the purge line should be routed?
I'd be very grateful for any information!
Thank you!
[SOLVED] 1999 s70 missing bolts and purge line placement Topic is solved
It Sounds like they slapped it back together somewhat
The self tapping 8 or 10 hex head screws for the air guide aren’t common but you can swipe one from the fender mount until you have a big enough order at FcP to get free shipping. ($50)
The engine mount bolt is more critical , you can pull a second and match or get the part number from the Volvo parts webstore. Link below
The purge line comes up the right side of the subframe, across the front of the subframe , then goes up to the purge valve. If they broke the plastic part, it’s common and bad practice go run it under the engine
The plastic 10mm hex nuts for the liner are either junkyard items or also FCP
items
https://www.volvopartswebstore.com/show ... veLine=457
items
Parts store shows three different part numbers for the mount bolt. A good place to sort these out is skandix.de They often list dimensions of the bolts in question so you can match up
982797
982819
985163
982797
982819
985163
Purge line is non critical. You can use any decent vacuum line to join the plastic to the purge line. It is important for engine function though. In a piece of engineering I still don’t understand , Volvo uses this line for both purge and fuel pump pressure regulation.
z80
- Year and Model: 1999 s70
- Has thanked: 3 times
- Been thanked: 6 times
Ok, I've finally received the parts. Everything fits perfectly.
Air duct bolts are 985743,
air duct washers are 986500,
and front engine mount "flange screw" bolt is 982819.
I've decided to not order plastic nuts for wheel well liners. They are a little bit too expensive for a non-critical plastic part. Took measures using an existing one. Going to 3d print an approximate replacement.
If you pm your address I can send you a couple.z80 wrote: 19 Mar 2023, 23:27 Ok, I've finally received the parts. Everything fits perfectly.
If 3D print a 10mm hexnut with a wide flange I’ll buy 100 of them. I want to be able to drill them to size to fit a worn mount screw , so no aperture wanted
Thanks for part numbers!
