I see. I didn't think about the amount that stays in the torque convertor and other places, unless flushed. I need to start thinking about replacing the ATF in my cars.
1997 850 Engine & Transmission oil change results / requesting feedback
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 130 times
Re: 1997 850 Engine & Transmission oil change results / requesting feedback
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
moses3
- Year and Model: 1997 850 GLT
- Has thanked: 68 times
- Been thanked: 5 times
I don't flush, some recommend 4 drain and fills spaced out 100 miles apart. I'm new to Volvo, I've worked on Toyotas for 30 years, and for me, drain and fill once per year seemed to be the best. Since this car is new to me, maybe every 6 months.454cid wrote: ↑09 Mar 2023, 10:41I see. I didn't think about the amount that stays in the torque convertor and other places, unless flushed. I need to start thinking about replacing the ATF in my cars.
- Has thanked: 1505 times
- Been thanked: 3818 times
moses3 wrote: ↑09 Mar 2023, 11:49I don't flush, some recommend 4 drain and fills spaced out 100 miles apart. I'm new to Volvo, I've worked on Toyotas for 30 years, and for me, drain and fill once per year seemed to be the best. Since this car is new to me, maybe every 6 months.
It’s a “Toyota “ transmission, of course.
- foggydogg
- Has thanked: 83 times
- Been thanked: 402 times
moses3 wrote: ↑09 Mar 2023, 11:49There is a method described both on the Forum and in several Y/T vids for pulling the discharge cooling line from the transmission to the radiator and pumping the fluid into a container 2-3 quarts at a time, stopping the engine and adding that measured amount back until the whole fresh 8 quarts are on board. Since the transmission isn't doing any work - no clutch packs are engaged, essentially nothing is turning except the pump gears - it's a method used for years with good results.
