With my 'R' I get about what you do in city driving. On the highway I get maybe 23-24mpg on a good day at around a steady 70-75 mph.
With my Non-turbos I used to get nearer 32 mpg on the highway.
Restoration: I Bought the Cheapest Running 98 V70 T5M (2023)
- Has thanked: 2210 times
- Has thanked: 317 times
- Been thanked: 531 times
My cousin's old NA S70 got around 30 mpg on a few longer highway trips he took. They can get great gas mileage!
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
I've managed near 30 mpg in a T5M. But it was 450 highway miles of down hill, so not sure that really counts.
I would always average 26 highway, and that was with a really worn out and tired engine. I think the 5spd helps a lot. My 99 wouldn't do better than 23.
Knows enough to be dangerous
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Same here. I get 25mpg with my 96 NA 850, but I only get about 22.x with my 99 S70 GLT.... almost all highway, with cruise on, fairly flat terrain. Granted it's winter, so I'll get some mileage back when we switch to summer gas. The best I've ever gotten with the S70 is 25mpg... once maybe twice?bmdubya1198 wrote: 26 Feb 2023, 20:11 How do you guys get such good gas mileage? I can't get better than 19 mpg in normal conditions. On longer highway drives, if I reset the average, I can get it up around 22.
Last time I asked about mileage I was told it was driving style/speed, but I'm not out there racing.
I have not pulled the plugs on the S70, or had a scanner hooked up to it. I don't have anything that seems to want to talk to it.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 987 times
- Been thanked: 1078 times
Alignment for all four wheels off? Tires not inflated to max tire rating? Bad thermostat? Bad plugs? Brakes or wheel bearings dragging? My T5 gets about 24/25 MPG at steady 70 MPH these days. This is after warm, up to speed, and then resetting the MPG reading.
Well our roads are a little hill-y and curvy, and I don't do a TON of highway driving in this car. That probably contributes to reduced gas mileage.
Ironically the average MPG in my X5 (daily driver) currently is about 20. It's hilarious.
- WhatAmIDoing
Not to brag, but I was getting 24mpg driving nothing but hilly, curvy back roads.bmdubya1198 wrote: 27 Feb 2023, 12:28 Well our roads are a little hill-y and curvy, and I don't do a TON of highway driving in this car. That probably contributes to reduced gas mileage.
Be quiet over there!WhatAmIDoing wrote: 27 Feb 2023, 15:41 Not to brag, but I was getting 24mpg driving nothing but hilly, curvy back roads.![]()
- WhatAmIDoing
Driven a little over 1000miles already. Nothing really to report. Have an ABS code for the right rear wheel speed sensor shorted to ground. And got an evap system large leak code after running through 2.5 tanks of gas. Have intermittent problems with the ECC. I suspect the module is bad, but I can't find my known good spare. Other than that, just plugged my second tire in 2 weeks.
Still getting about 24mpg. Should really replace the cap and rotor.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I'm getting 24/25 mpg. I was getting 26+ before I started improving things.
1999 V70 GLT
1999 V70 GLT
