So I've been thinking of different turbo upgrades for my volvo and since the car only has 5 cylenders therefore I can't have two exhaust manifolds for two turbos, would it be possible to do a compound turbo setup with a high pressure turbo at the manifold and the stock low pressure turbo thats on it now after that.
Sorry if I put this question in the wrong section.
2005 XC70 compound turbo setup?
XCSwaggon97
- Year and Model: 2005 xc70 2.5T
- Has thanked: 1850 times
- Been thanked: 1710 times
Your transmission will be the limiting factor here. The automatic transmissions I understand have a max capability of around 320 bhp. So you would be able to get to that easily with a regular turbo and a tune. If you did away with the AWD and fitted a manual trans then you can go crazy.
XCSwaggon97
Well you never really need performance parts but I still want them lol, I also just want to build something a bit different than what most people do to them.
Also im in ontario so what manual transmission or car can I pull one out of and how difficult would it be to swap to manual. Im sure there's forums explaining this already so ill go try find thoes in the meantime
2005 XC70 (getting it tuned soon).
For AWD manual transmissions you are limited. The 'spaceball' V70/S60 'R' are about it unless someone else wants to chip in. There was a manual trans in a 97 850 AWD but they are hard to find these days.
If you want to do away with the AWD then there are more options.
XCSwaggon97
Yeah I would like to keep my awd as I am hoping to build the car into an offroad car but still has the capability to throw tires on it for the dragstrip but thats the end goal of the car once I swap the better 5 cylender into it
- ignatz
- Year and Model: 2006 S60 t5m
- Has thanked: 17 times
- Been thanked: 33 times
Great video on YouTube, Rally heaven, Lancia Stratos and Lancia Delta S4.
The Lancia Delta S4 is Supercharged/ Turbocharged 500 bhp with all wheel drive. The video shows three separate rally cars that let the imaginations of engineers run wild within the "former" World Rally rulebook.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
2005 S60 2.5t awd
XCSwaggon97
I would love to own a Lancia delta
