No sir I certainly didn't... I only replaced the one strut on the passenger side. The noise seemed to come from the left side of the car at first now it seems as if both sides are making noise. Is it likely that I have two bad spring seats? If thats the case I should get a new strut for the drivers sie as well. I'll check it out.
Thanks agian MIJ!
A loud knock when I crank the wheel left. 2000 S70 Turbo
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Yes! On Volvo's I've never had any luck just replacing struts. When I do these, I always at least do the spring seats and also inspect the strut mounts and change them if they look worn. (The strut mount is the one at the very top that has a gear in them). That said, avoid the cheap Scantech spring seats...they might last a year at best.
- 2057 Views
Last post by cn90
- 2336 Views
Last post by GazmorGuri75
- 819 Views
Last post by Sp614
- 1023 Views
Last post by Tubbs76
- 6057 Views
Last post by chukey7
