Heh guys. I am going to have a mechanic I trust to replace the oil breather box and the various hoses that go along with it.
For someone that knows what they are doing, how many hours of labor should they normally be charging me if there is no trouble?
2002 V70 (Labor Hrs. for Oil Breather Box)
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 151 times
- Been thanked: 4 times
- Has thanked: 927 times
- Been thanked: 1000 times
Perhaps 4 hours for experienced Volvo tech. Just my guess. I did it and it took me much longer.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 69 times
- Been thanked: 481 times
Its "involved" and labor heavy. DIY'ers mention a long day or more, thats why I haven't done mine.Mr. Detail wrote: ↑16 Mar 2023, 07:33 Heh guys. I am going to have a mechanic I trust to replace the oil breather box and the various hoses that go along with it.
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
PCV is much simpler on N/A engine. 4 hours max. He may sell you that this or that bolt was very hard to access, but that would speak to his lack of experience with PCV on these engines. Both hard to access bolts are in fact not that hard when you approach them in the right way.Mr. Detail wrote: ↑16 Mar 2023, 07:33 Heh guys. I am going to have a mechanic I trust to replace the oil breather box and the various hoses that go along with it.
- Been thanked: 472 times
If you replace the thermostat at the same time, then the notorious bolt issue is no longer an issue.
I wrote my experience in this forum.
Search for the thread title "PCV R&R - Losing the battle to the dreaded hidden intake bolt"...
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 126 times
- Been thanked: 116 times
Full day for me. Get the whole kit with all the fuel rail orings and copper crush washers and all of the odds and ends and then you will avoid a trip to the parts store.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Has thanked: 2655 times
- Been thanked: 1248 times
gks
- Year and Model: 03 V70
- Has thanked: 2 times
- Been thanked: 2 times
Just had this done locally. Was billed for 4.5h labour and the total bill for PCV system replacement came to $700 with parts. The mechanic wanted to drop and clean the oil pan, I declined, but this may have been the wrong call—my engine is still leaking. His quote with the oil pan cleaning was $1500
vtl
Clogged drainage does nothing to crank vacuum. At least not until the oil trap fills in completely.
What you may see is a worn compression rings allowing more blow-by gases in crankcase than PCV can extract. When I did my 05 engine with 220k miles couple of years ago, the upper piston rings placed in the lowest working spot of the cylinder (where the taper is the least) measured 0.9 mm of thermal gap, which is over the roof.
- 24 Replies
- 5065 Views
Last post by Darkskies65
- 15 Replies
- 2619 Views
Last post by Bluevanacd2005
