Volvo LCA bushings since 10/2015, did 88k miles, including ~15k miles offroad. Still strong. The originals were replaced at 140k miles.xHeart wrote: 23 Mar 2023, 07:29 Lol! I'm running on Meyle HD LCA since 3/18/2013; paid $85.65 each! FWIW, I did a complete front refresh after reading CN90's posts.
Ride Quality with HD Control Arms and Ball Joints ?
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Mike98
- Year and Model: V70 2006 NA
- Been thanked: 4 times
Did the blue silicone boots fail on your IPD HD ball joints ? So far my boots look OK after 10K miles but the winter climate in Va is mild compared to New England.chris11211 wrote: 23 Mar 2023, 03:16 .......
My 2 ipd ball joint didn't last 2 years, as well as the silicone top engine mount.
I'd 100% be ready for those ball joints to fail. Silicone boots is the entire point for selling this thing and it doesn't hold up to new england seasons.
2006 V70 M56 NA
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
Yes they actually failed 1.5 years in. I heard very loud squeaking while turning late fall, but I just couldn't get to it until the spring.Mike98 wrote: 23 Mar 2023, 13:06
I'd say I almost got to 10k so I think you should give it an inspection, but the only way to get a full 360 view on the boots is to remove the knuckle off and see whats going on. Also, I actually thought it was only one boot, but one was squeaking while the other I could see it broken.
And then there was this weird corrosion coming off the boot. Made the entire knuckle somehow glued to the control arm.
Mike98
The ball joint boot in your pictures looks black. The IPD HD ball joints that I bought directly from IPD in August 2021 have blue boots. Did IPD change the boot color or material ?chris11211 wrote: 23 Mar 2023, 19:55
2006 V70 M56 NA
- chris11211
I got it indigo just like what's on their picture on the website. Also it's just darkened due to just where it's at.Mike98 wrote: 23 Mar 2023, 22:13 The ball joint boot in your pictures looks black. The IPD HD ball joints that I bought directly from IPD in August 2021 have blue boots. Did IPD change the boot color or material ?
Mines is older, and I think they just tend to buy the cheapest blues at whatever time they order it from Taiwan.
Mike98
I never followed up with the resolution of my ride harshness problem. I made these changes to the front and rear suspension:
1. Bilstein B4 front struts and rear shocks replaced with Sachs OE from FCP Euro.
2. Installed new Febi 18481 strut mount bearings even though the existing Febi 18481s only had 10,000 miles of use.
3. Replaced IPD HD spring seats with Sachs 30683637 (Heavy Duty version from XC90)
4. Kept IPD HD control arms as they looked fine after 10,000 miles of use
5. Kept IPD HD ball joints as they looked fine after 10,000 miles of use
The result was that ride harshness was eliminated. Driving over expansion joints and minor road surface irregularities is no longer excruciating. The car is now pleasant to drive even on rough roads.
Mike
Mike
2006 V70 M56 NA
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
I think the biggest difference to the ride quality is the SACHS shocks. Spring seats I guess somewhat. But mostly in my opinion shocks and LCA bushings.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.dikidera wrote: 01 Jul 2024, 04:33 I think the biggest difference to the ride quality is the SACHS shocks. Spring seats I guess somewhat. But mostly in my opinion shocks and LCA bushings.
+1 on the SACHS. All the other suspension parts contribute to a handling issue / feel in the wheel. Ride is mainly from struts and shocks and springs it you go aftermarket. We are not talking about any of the parts aforementioned being broken but just wear and tear.
As for the photo I didn't read the entire post thoroughly but to be fair the IPD ball joint boot was pinched / mechanical damaged and not from failure.
dikidera
My shocks are dead. When I removed mine from the car...it compressed all by itself. I had a hard time putting it all back together until I find replacements.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Yes, I have both of these. The ride is as stock. I have replacement OEM struts and shocks as well.
- 24 Replies
- 6838 Views
Last post by oragex
- 12 Replies
- 3840 Views
Last post by BlackBart
- 1634 Views
Last post by erikv11
- 1961 Views
Last post by chris11211
- 354 Views
Last post by OliPhant
