I've followed the instructions. When installing the patches, I did get an error but it finished anyway (I think).
When trying to log in (using admin), I can click in the box and see a vertical cursor blinking but can't type anything. I've tried typing. Pasting. Nothing works.
I'm using Edge in IE mode. If I don't use IE Mode, I can't even click in to that Username Box.
I searched the thread and saw that someone else had this problem, but didn't see a fix for it.
How can I get past this?
VIDA 2014D_Repack install on Windows 10, any version.
ChipStewart
- Year and Model: 2004
I followed the instructions and the install seemed to go smoothly, but the unit isn't being recognized by the software. When I plug it into the computer, Device manager shows it as "USB Serial Port (COM14), but the VIDA drop-down "Communicatoins tool" box only shows "Not selected". I tried the DiCE Diagnostic program, but it doesn't show under "Select Device".
Whether or not the DiCE is plugged in, the "Firmware status" and "Vehicle interface status" lights are solid red and the USB com status light is blinking blue.
I assume I got a bad DiCE unit and will have to ship it back to China? My only car is out of commission and I need to get this going ASAP!
BMWFan
- Year and Model: 2007 XC90
I've seen forum posts where when the DiCE device is properly installed, it doesn't show up under USB devices. There's a completely new category called DiCE Hardware that shows up in Device Manager. I don't remember or have the links handy, but maybe doing a search on something like that might give some ideas.
I suspect it's not bad. Just not installed correctly. But I don't know how to fix it. I have my own problems with VIDA not letting me type in the Username box to log in.
And since I don't really know how to install this software, other than to follow directions - I may be leading you astray. If so, I'm sorry.
- RickHaleParker
- Been thanked: 978 times
Gray Case or Blue Case?ChipStewart wrote: 25 Mar 2023, 09:40 Device manager shows it as "USB Serial Port (COM14), but the VIDA drop-down "Communicatoins tool" box only shows "Not selected". I tried the DiCE Diagnostic program, but it doesn't show under "Select Device".
Active
Past
Past
ChipStewart
Gray. Also, I forgot to mention lights 4 (firmware status) and 1 (vehicle interface status) are lit solid red and light 2 (USB com status) blinks blue.
Hi all !!! I installed VX Diag and Vida on my Win 10 Pro laptop. Everything was OK. When I start Vida, I enter the VIN number and select gearbox and w/o sunroof, click OK and I got message "getCommToolSettings(...).DiagnosticAllowed is not a function". Also, the Vida doesn´t start in IE but in Edge. What is this releted to?? Thanks!
- hal9000f
- Year and Model: 2013 V70 - 1997 855
- Has thanked: 2 times
- Been thanked: 3 times
Vida must start in IE.kekec01 wrote: 13 Apr 2023, 13:09 Hi all !!! I installed VX Diag and Vida on my Win 10 Pro laptop. Everything was OK. When I start Vida, I enter the VIN number and select gearbox and w/o sunroof, click OK and I got message "getCommToolSettings(...).DiagnosticAllowed is not a function". Also, the Vida doesn´t start in IE but in Edge. What is this releted to?? Thanks!
Open Edge browser
Go to Settings
On the right choose "Default Browser"
Allow sites to be reloaded in Internet Explorer mode (IE mode) - Allow
Internet Explorer mode pages - Add http://localhost/Vida/
Restart Edge.
It should work now.
[1981 ... 244gld6 D24] - 1992. > 2004.
[1997 ... 855tdi D5252T] - 2004. > today.
[2013 ... V70d3 D5204T7] - 2022. > today.
Will try. Thanks!!
Edit: Now I have another message: " Object doesn´t support property or method 'DiagnosticAllowed' " but now I can enter into the parts catalog which I couldn´t before.
I try to enter in Vida without car connection. I asume that is not the problem or...??
- hal9000f
It's not a problem unless you want to use the Diagnostics tab.kekec01 wrote: 14 Apr 2023, 02:51 Will try. Thanks!!
Sorry, didn't stumble upon that message...
- 11072 Views
Last post by Stasiuss
- 4961 Views
Last post by big305
- 5932 Views
Last post by RickHaleParker
- 3052 Views
Last post by rusty volvo
- 4422 Views
Last post by wizechatmgr
