Volvo CAN is 3.3v.RickHaleParker wrote: 19 Mar 2023, 15:00I have done the CAN level at 5V ... no damage.
If you want to level shift. Use a CAN Transceiver with level shift built in.
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
myname
- Year and Model: 2007 XC70
- Been thanked: 4 times
I still cant get Cemcracker to do much of anything. I took a full video here, showing the crash. I assume at this point my knockoff Dice just isnt up to the task. Please let me know what you think.
Thanks
My car: 2007 XC70 YV4SZ592771280324
Thanks
- Silencer711
- Year and Model: 2007 S60 2.5T AWD
PM'ed youT5Luke wrote: 16 Jul 2022, 16:18 If you have a matching car and Dice-206751?
PM me to get software for a try and report back to the forum...
2007 S60 - P2 - B5254T2 - 2.5T - AW50 AWD
- PAST -
2002 S40 - NEDCAR - B4204T3 - Base 1.9T - AW50 FWD | (Given Away)
2001 S80 - P2 - B6284T - T6 - GM 4T65 AWD | (Crashed)
- PAST -
- Jackw16
- Year and Model: 2014 V40 D3
Hi guys,
just kind of checking in, i plan on reading up on this post to see if theres any updates to make to the wiki and i finally have a good few days time to really improve the wiki more, i do have one question though, on p3 i took my cem out as i was having a hard time getting it to stay in programming mode and therefore slowing down the cracking as it would constantly re-enter programming mode, im now lending this device to a friend but before i post it to him i wanted to see if anybody has had any luck figuring this out, its a V40 that im finding it hard to keep in programming mode, many thanks, Jack
included a picture of my device setup incase its the length ive extended the can bus by etc, i currently think it could just be the length of these wires but any help is greatly appreciated
P.S the Esp01 is just being used to connect to wifi and then share what the teensy is outputting on serial over wifi to a webpage for remote monitoring, or via a phone locally.
vtl
V40 is P1, no?
Adding a pause between CAN requests usually helps to early P3 CEMs to stay asleep, however I found it was still quicker to go as fast as it can and re-enter programming mode when needed.
How often is it dropping off the programming mode?
Dudde
- Year and Model: 2005 V70 and more
- Has thanked: 17 times
- Been thanked: 17 times
What is the 3 byte pincode that is used with DHA? Is it different from the 6byte pin or is it possible to convert it to 3 byte pin? Or am i missing something here?
- 9751 Views
Last post by RickHaleParker
- 9997 Views
- 27 Replies
- 30863 Views
Last post by cn90
- 10 Replies
- 11705 Views
Last post by jonesg
- 6771 Views
