I just had my mechanic splice out an h11 socket because the stock one burned out. Unfortunately, we discovered that the housing for the bulb has warped or is out of shape and the only way for the for the bulb to stay in place is to have one of the teeth barely hold on to the metal. Has anyone fixed this? Maybe the angle is not aligned ?
When I bought the part on eBay not there was nothing wrong. I'm guessing I need to swap out for another used one, right?
h11 housing seems warped. Any fix? 06 s60
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
- It's hard to see, but if you do an extreme close-up you'll see that it's being held by one tooth.
- PXL_20230329_160911052.jpg (197.5 KiB) Viewed 199 times
