Hi,
I checked the washer today and found that it does not spray anymore.
I put in new fluid, and still nothing.
I hear the pump running though.
Think it could be a clogged line or something? How would i troubleshoot that?
Thanks.
Windshield Washer Not Working
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
You're in luck because I just had to troubleshoot this. With the hood open, do they spray? In my case, The rubber line shifted and got pinched by the hood hinge. Is the line blown out and leaking somewhere? It runs from the bottom of the tank, above the fender liner, then up through the fender by the hood hinge, then on to under the hood insulation. There are also multiple check valves along the way. One by the pump near the inline filter (could be plugged), then one at each nozzle which doubles as the T and L fitting. They can clog up. Do you have headlight washers? Do you have the fan pattern or dual stream washer nozzles? The 2 stream ones can easily be cleaned with a safety pin. To test the pump, you will have to disconnect the line at the pump and quickly connect another long length of hose that's at least taller then the fender, or else gravity will push the washer fluid out. And general safety note, wear gloves and glasses, as you really don't want washer fluid on or in your body.
Knows enough to be dangerous
- Has thanked: 2203 times
The check valves can stick as they get old and if they don't see regular use, same with the pump.
I have posted a thread on the subject before and on how to open the valves and check them.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I need to go through the system on my 850, too. My 99 S70 works fantastic, so I know the 850 can be better.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- MrAl
Hi,WhatAmIDoing wrote: 31 Mar 2023, 09:27 You're in luck because I just had to troubleshoot this. With the hood open, do they spray? In my case, The rubber line shifted and got pinched by the hood hinge. Is the line blown out and leaking somewhere? It runs from the bottom of the tank, above the fender liner, then up through the fender by the hood hinge, then on to under the hood insulation. There are also multiple check valves along the way. One by the pump near the inline filter (could be plugged), then one at each nozzle which doubles as the T and L fitting. They can clog up. Do you have headlight washers? Do you have the fan pattern or dual stream washer nozzles? The 2 stream ones can easily be cleaned with a safety pin. To test the pump, you will have to disconnect the line at the pump and quickly connect another long length of hose that's at least taller then the fender, or else gravity will push the washer fluid out. And general safety note, wear gloves and glasses, as you really don't want washer fluid on or in your body.
Ok thanks ill check that out asap.
- MrAl
Hi Neil,scot850 wrote: 31 Mar 2023, 10:22 The check valves can stick as they get old and if they don't see regular use, same with the pump.
Remember the thread?
- MrAl
Hi,scot850 wrote: 31 Mar 2023, 19:31 Try and see if this one helps:
viewtopic.php?p=594741&hilit=windshield ... es#p594741
Oh ok thanks.
Looks interesting. I'll have to try to find the valves i guess.
I couldnt do much today it was raining out. Just took off my solar panel for some minor maintenance. Got back in the house as soon as possible.
- WhatAmIDoing
I believe the link was posted in my V70 restoration thread, along with some additional guidance on the subject. Link in my signature.
- MrAl
Ok thanks. Today i had to reinstall my solar panel on the car and almost got blown away by the cold wind, so i am waiting for a better day to do some more stuff that has to be done outside of the car.WhatAmIDoing wrote: 01 Apr 2023, 16:43I believe the link was posted in my V70 restoration thread, along with some additional guidance on the subject. Link in my signature.
- 635 Views
Last post by MoVolvos
- 228 Views
Last post by pfmet
- 15 Replies
- 8749 Views
Last post by volvolugnut
- 36 Replies
- 24751 Views
Last post by StickyPocket
- 19 Replies
- 3831 Views
Last post by jvl
