2001 V70 Missing Vacuum Line between Fusebox and Air Filter
106 Miles 2 Chicago
Year and Model: 2001 V70; 2019 XC90
Post by 106 Miles 2 Chicago »
I found the hose fitting on the aft side of the air filter box missing a elbow / line missing and just aft of that in front of the fusebox.
Is there an identification of what this line is and part number. What purpose does this missing line serve?
I could not find it.
Thanks.
106 Miles 2 Chicago
2001 V70 AIR INTAKE MISSING FITTING.png (508.55 KiB) Viewed 827 times
Been thanked: 4065 times
It’s part of the air filter box heated air system. Vacuum comes up to the air box to one of the two nipples, and the temperature of the air box meters the vacuum ftom the other nipple down to the flap that selects hot or cold air into the air filter box.
Those rubber nipples are available from Volvo or aftermarket
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
abscate wrote: 09 Apr 2023, 10:55 It’s part of the air filter box heated air system. Vacuum comes up to the air box to one of the two nipples, and the temperature of the air box meters the vacuum ftom the other nipple down to the flap that selects hot or cold air into the air filter box.
might not be needed in texas heat.
