Looks like I have that dreaded broken plastic around the socket where my brake light bulb socket is and I will need to replace the whole upper lamp. I have a new/used lamp but I have no clue as to the size of that small hex nut (2X) that holds the whole lamp in place. Would any of you have an idea of the mm size? I am guessing I will need a small swivel also just to access this.
(See attachment)
2002 V70 Tail Lamp Hex Nut Size ?
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
Mr. Detail
Thank you gentlemen!
I have a 10mm socket but not the swivel portion. Also I can tape the socket to the swivel so it won't drop down the cavern but how do i keep from losing the nut once it is loose?
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Sometimes, in this situation, I’ll hold one of those extendable magnets up against the bottom of the socket while I unscrew the last few turns. That keeps the nut attracted to the socket.Mr. Detail wrote: 10 Apr 2023, 06:08 Thank you gentlemen!
….but how do i keep from losing the nut once it is loose?
- Has thanked: 1611 times
- Been thanked: 4072 times
Or even a magnetic 10mm socket
Mr. Detail
Is a "wobble" joint different than a "swivel" one?
- Has thanked: 987 times
- Been thanked: 1078 times
I suggest you buy two tools before you do much work on any vehicle:
1. A magnetic retrieval tool on a flexible stick.
2. A retractable claw retrieval tool on a flexible stick.
Both will save you much frustration. They are very cheap if you find generic brands.
- Been thanked: 504 times
A trick I use when dealing with difficult nut (other than magnetic socket)...get a small piece of paper towel
and stuff in the socket with some part sticking out of the socket.
Once inserted, the paper towel keeps the nut from dropping.
I wrote a detailed DIY here...
2004 V70 - Tail Light Assembly removal
viewtopic.php?t=62296
- 1088 Views
Last post by zombielinux
- 9 Replies
- 3572 Views
Last post by vtl
- 12 Replies
- 2163 Views
Last post by oragex
- 1375 Views
- 18 Replies
- 2525 Views
