CEM not sleeping? 2005 XC90
Hey all! The Volvo was purchased with 100K for $750. It runs nice after installing new plugs and coils. It does stall from time to time and must be restarted. The reason for the low price, was that of a parasitic draw of 400ma. With the car "asleep", I've found that there is 12V on many of the CEM fuses and under the hood in that fuse box. I pulled the top CEM connectors and found no water damage. After the CEM disconnect, the fuses under the hood showed no voltage, the draw disappeared, but the CEM still showed 12V on some circuits. I'm trying to make a decision whether or not to have the CEM serviced ($599 with XeMODeX Inc US). One would think that the ignition would initiate the 12V distribution... Has anyone seen this one? Thanks! Dean
Top
Top
chitownV
- Year and Model: 2008 XC90 3.2
- Has thanked: 15 times
- Been thanked: 40 times
You may just end up sending your CEM to Xemodex, but you can contact them so they can help you trouble shoot. They have seen pretty much all the scenarios and know the issues way too well.
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
- Has thanked: 1511 times
- Been thanked: 3829 times
I suspect the CEM has many 12V circuits active with key out. Current drain is important, not the mere presence of voltage.
