My Right Outer Tie Rod is bad, do people typically replace both right and left at the same time? Car has 160,000 miles.
Should I also replace the inner tie rods while I'm in there?
1997 Volvo 850 GLT Tie Rods
- Has thanked: 2197 times
- Been thanked: 1851 times
It is one of those things, if you know the history of the car, one may have been damaged and that is why only one is bad as the other was replaced. If you don't know how to check these yourself, find someone that can. If the inners and the other outer are good I would not replace. If there is doubt I would replace both outers as often the cost to have 2 fitted is not that much more and you have to have an alignment anyway. Definitely have the inners checked for play and if they are good leave alone.
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I did all four on my '97 855 about 7 or 8 years ago. The inners were in good shape at that time and could probably have been left alone.
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
On my 98 S70, I ended up only doing the one outer the first time, only to end up doing all four about a year later at around 250k miles. I also did control arms and struts, and it had a dramatic improvement in handling, despite the majority of the components being seemingly "fine". If you find your car wandering down the highway or your steering lacks precision, then I would consider a whole front end overhaul.
You are in it for an alignment no matter what. I would at least do the inner and outer on that side, and thoroughly check the other tie rods, control arms, struts, and other front end components.
Knows enough to be dangerous
moses3
- Year and Model: 1997 850 GLT
- Has thanked: 68 times
- Been thanked: 5 times
This problem started after I replaced both control arms and the sway bars, and my theory is that basically when you put in new suspension parts that are nice and tight, they're going to put extra load and stress on the old parts that might already be weak, and then they break. So, usually a lot of these parts need to be replaced at the same time. I'm a little bit hesitant to do the inner tie rods because people said that the steering rack is very sensitive?WhatAmIDoing wrote: 12 Apr 2023, 09:50 On my 98 S70, I ended up only doing the one outer the first time, only to end up doing all four about a year later at around 250k miles. I also did control arms and struts, and it had a dramatic improvement in handling, despite the majority of the components being seemingly "fine". If you find your car wandering down the highway or your steering lacks precision, then I would consider a whole front end overhaul.
- WhatAmIDoing
I had no problem doing my tie rods. I used a pipe wrench for the inners. Just don't put too much excessive force into it. Since you've already done control arms, then yes I'd do all 4 tie rods.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
It's my understanding that in general outer tie-rod ends get more wear due to greater movement during use. This seems to be true on my truck. I would likely replace just the outers unless the inners were obviously bad. Both my Volvos are low mileage so I haven't had to deal with this on a P80.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Been thanked: 4064 times
Once you get the liters disconnected it’s easy to feel play in the inners. Also, take a good look at your boots when you are in this job. Easy to do with the rods disconnected.
Good boots here
Good boots here
- 2945 Views
Last post by davhaney
- 10 Replies
- 2109 Views
Last post by 2002V70XC
- 11 Replies
- 3939 Views
Last post by flatlander84
- 1154 Views
Last post by 98v70dad
- 27 Replies
- 7411 Views
