I’ve almost given up, but then I saw this one..
Keshavsmith
- Year and Model: 98 S70
- Has thanked: 21 times
- Been thanked: 11 times
Re: I’ve almost given up, but then I saw this one..
Here’s a few more things I found in the folder he gave me… from 2015 and 2008. Also, I think the original sticker?
- 8945F1D5-6093-4B27-92EB-40B4D5EC92FC.jpeg (426.93 KiB) Viewed 507 times
- C991A8D5-9B14-417D-A450-32E9CF06F874.jpeg (331.45 KiB) Viewed 507 times
- BB25BE61-5CF5-4E0A-AC9A-49F0C3DDADBC.jpeg (382.6 KiB) Viewed 507 times
Keshavsmith
I was responding to the Highlander comment. I think I figured out how to do the quote thing you guys do, which obviously makes it clear which comment one is replying to.. I’m still learning to navigate this site. : )foggydogg wrote: ↑10 Apr 2023, 20:24The F/B ad seems to say the car on offer is a '98, so some confusion may have crept into the thread.Keshavsmith wrote: ↑10 Apr 2023, 20:19 Hahah. It was an 07’ with 190k miles on it so no wealth over here.
One common place for oil leaks on the pre-'99 turbo cars is the oil cooler lines, again, not a big issue but annoying. I have removed them completely on two cars and installed the delete plate, end of problem.
- Has thanked: 1500 times
- Been thanked: 3812 times
Looks great, a loved T5 that got fixed when needed. You should get a good 5 years from this car if you stay on top of it
Once a month , the hood goes up and you check all over the engine for leaks of oil , coolant, power steering fluid, and ATF.
In the next three months, replace that ATF using the Gibbons or drain and fill method. Once a week for three weeks until most of the ATF is fresh.
If it been since 2008 for the cap, rotor , and plugs, those are due pretty soon but can wait for now
You are probably coming up on your third timing belt interval on a 1998. It depends on both time and miles. It isn’t critical, rush out and do tomorrow if it is overdue, but needs to be done in next month
Interval is 7 years/70k miles
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
That looks to have a persistent P0455 code. Seeing as they "found no leaks", I'm guessing it would be above the tank. It's not a real issue, but annoying. My wife's '97 GLT had a P0455 code for 3-4 years until I finally traced it to a chewed up hose on top of the tank.
It looks like it was maintained to some extent, so that's nice.
We can work out a time for me to look it over here in the near future.
Glad you're happy with it.!
- Has thanked: 1839 times
- Been thanked: 1709 times
I saw that too. I guess if they didn't have it then maybe they had to call Volvo..............!??
- Has thanked: 2652 times
- Been thanked: 1242 times
The old days of ~$400 timing belts and home vs.mobile phone numbers!
I think this is going to turn out to be a good car.
- Chuck W
"Sweet Return Customer Coupon $5.00 off labor"...
Don't do us any favors, geez.
Probably a 1/2 hour minimum labor rate charge
- FireFox31
- Has thanked: 158 times
- Been thanked: 300 times
Great job getting the car. And the original sticker too! When someone keeps the original sticker, it tells me they care that much more than the typical car owner. Get any issues sorted, do the preventative maintenance that abscate recommended (and a monthly check of tire pressure and bi-monthly check of tread wear), and the car should last you a long time.
FireFox31
