2006 V70: Replace radiator as preventative measure? Topic is solved
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
I would be more worried about headgaskets than radiator failures, that being said, my radiator exploded due to a bad headgasket, the exhaust gasses produced so much pressure it failed so I actually do need to replace it.
I found a radiator brand NRF, it looks alright. What would you guys say about this brand?
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Most of anything is ok for you, since your car has no automatic transmission. Aftermarket radiators have a crappy ATF cooler plumbing: weak, inefficient.
hughiescho
Year and Model: 2006 V70 2.5T
Has thanked: 15 times
Been thanked: 3 times
Post by hughiescho »
Thanks for your above perspective Abscate. I really appreciate it.
hughiescho
vtl wrote: 13 Apr 2023, 08:28
hughiescho wrote: 13 Apr 2023, 07:22
vtl wrote: 12 Apr 2023, 10:13 I did just that: a new Volvo radiator that I've luckily got with 1/3 discount. Bypassing the cooler is not a good idea in cold climate.
I appreciate the information--thanks vtl. Here in Canada the Volvo radiator lists at $670... one-third of that I could stomach.
Just under $300: https://www.tascaparts.com/oem-parts/vo ... r-31319056 Taxes and shipment and currency conversion will add to that, but still can be cheaper than 670.
Quite compelling -- thank you for this link!
hughiescho
scot850 wrote: 13 Apr 2023, 10:21 This is not an official Volvo reseller but claim to be selling Volvo OE radiator for around $500 with taxes. Shipping? $40 to Calgary.
https://www.volvopartsca.ca/oem-parts/v ... NS1nYXM%3D
Thanks for this Neil. I shall have a look at this source too.
hughiescho
dikidera wrote: 14 Apr 2023, 06:02 I would be more worried about headgaskets than radiator failures, that being said, my radiator exploded due to a bad headgasket, the exhaust gasses produced so much pressure it failed so I actually do need to replace it.
Oh wow... Sounds like a hectic incident your car suffered. Thanks for sharing dikidera.
dikidera
Post by dikidera »
vtl wrote: 14 Apr 2023, 06:27 Most of anything is ok for you, since your car has no automatic transmission. Aftermarket radiators have a crappy ATF cooler plumbing: weak, inefficient.
No it exactly has an automatic transmission and am looking at the the ones who support it. NRF seems to support it.
vtl
Post by vtl »
dikidera wrote: 15 Apr 2023, 02:09 No it exactly has an automatic transmission and am looking at the the ones who support it. NRF seems to support it.
Get anything you can find, install aux cooler, bypass built-in ATF cooler. Should not be a problem in your hot climate and hilly terrain.
