- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Took all of the bolts too. I was thinking that I might buy two new ones for the main subframe attachment because those heads took some hits when the forklift picked up the car. I obviously got them off, but considering the torque it seems they are set at, I'd feel better with a couple of new ones.
1999 V70 GLT
1999 V70 GLT
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
scot850 wrote: 15 Apr 2023, 19:09 The bolts I pulled are the same as the others I have from other cars in my stash. Not 100% convinced of the 2 different bolt lengths. I'm probably wrong!
Yeah, the big bolts are a little longer, and the 3 others on the plate are a good 15mm or so longer, seeing as the bracket there is as thick as the brace tubing. The 4 bolts on the other plate are the same as the non-vert cars.Sveedy wrote: 15 Apr 2023, 21:05 Took all of the bolts too. I was thinking that I might buy two new ones for the main subframe attachment because those heads took some hits when the forklift picked up the car. I obviously got them off, but considering the torque it seems they are set at, I'd feel better with a couple of new ones.
You will need to add threaded inserts, unless your car has a vert subframe under it already for some reason. (if you have 2-bolt control arms, you don't have a vert subframe)
- Has thanked: 1613 times
- Been thanked: 4075 times
I think Volvo says new on the long ones into the snout whenever the subframe is removed. You don’t have to listen to Mother always, but an inspection protocol if you reuse would be smartSveedy wrote: 15 Apr 2023, 21:05 Took all of the bolts too. I was thinking that I might buy two new ones for the main subframe attachment because those heads took some hits when the forklift picked up the car. I obviously got them off, but considering the torque it seems they are set at, I'd feel better with a couple of new ones.
- Has thanked: 317 times
- Been thanked: 531 times
For that front brace, I would recommend rivet style nut inserts like these https://www.harborfreight.com/10-in-pro ... 58078.html
Inspect, clean threads, blue loctite, reinstall. Should be fine! Probably...abscate wrote: 16 Apr 2023, 00:18
- Has thanked: 2212 times
- Been thanked: 1853 times
You get different riv-nuts, aluminum, steel and stainless. I would go with the regular steel ones. They are more flexible where stainless are too rigid.
Those are exactly what I would have used, but I still have to check if they rear mounts are where the AWD prop-shaft bearing mounts to.
Tough call. I don’t like Loctite as it means dry threads , and in the rust belt that’s death.
I nickel antiseize them, torque to spec, then punch mark them.
Inspect marks daily for a week, weekly fir a month, then monthly for six months.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Have you experienced corrosion using Loctite? It's my understanding that it should also keep moisture out. I don't usually use it on the undercarriage, Though.abscate wrote: 16 Apr 2023, 16:25 Tough call. I don’t like Loctite as it means dry threads , and in the rust belt that’s death.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Interesting note on the loctite. I could see that potentially being a problem. I've had the privilege of replacing rear wheel bearings on a BMW that seems to have been up north. It's a 2015, and the effort I have to put into removing those rear axles was unbelievable. I absolutely destroyed one of the stubs, and the other one survived after some more careful heating and half a can of PB blaster. Man, I'm spoiled living in the south.
That said, the next day, I smoothly removed two axles without a single hammer impact from a 2005 BMW X5. Southern car... go figure!
xyna
- Year and Model: Volvo 740 1990
Took a while for me to check this forum again, but I literally just closed the door. Probably used too much force doing so. The internals of the motor in the window regulator is metal, but on the outside it is just plastic.CIK7 wrote: 05 Mar 2023, 12:13Has your car been in an accident? I suppose plastic could get old, but i think the window regulator is metal, isnt it? I didnt think that could crack.xyna wrote: 01 Mar 2023, 09:17 Took off my door panel to discover that my window regulator motor was broken in half. Replacing it went pretty good, considering that it was my first time. Wouldn't want to do it again, though.
Today I removed the wooden trim of my S70 that I am parting out, along with other parts of the interior and some AC piping with my friend who also has a S70 and needed some parts and wanted the wooden trim. Also worked on my slightly rusty 740 wagon, hoping to get it inspected for the summer!
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
Yesterday, I took the Rotten Tomato to Moore to look at a car. Left it running while looking at that car, while getting food from jimmy johns and chikfila, while getting groceries from aldi, and while in walmart. The ac did not run out or get weak, the engine stayed cool, and it performed very well. I even had a last minute detour to home depot in Ada to get 10 bags of mulch. Fat dog Spencer comfortably rested in 2nd row with the 60% split cushion folded up and blanket down. My girl Rose curled up next to me in the front seat awake and anxious. 2 dogs, 10 bags of mulch, and groceries. A semi-productive trip in a schmancy 5 speed; that was fun. I didn't like the laid-back careless attitude of the salesman toward maintenance of the car. But a fun trip nonetheless.
Im not kidding, i stress out because Im concerned it might overheat like the white one did, even though that was fan related, or like the more likely chance the 960 has in hot climates. But it worked good yesterday! Does anyone here have an elevated stress level about their Volvo failing in some way? Stress they dont have with their non-Volvo cars?
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
