bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
These will cause PTSD with cooling system issues... that's how a friend of mine was with his S60R lol.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I felt the same way. An all aluminum engine, coupled with a temp gauge that is a bit vague. So I mounted one of these Scan Gauge's.
I am able to watch the temp by degree, which has eased my mind considerably.
https://www.amazon.com/ScanGauge-Automo ... 61819&th=1
1999 V70 GLT
Has thanked: 2203 times
Been thanked: 1852 times
I fixed the stress level by giving the R to my wife to drive! :lol: :lol:
Neil
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
CIK7 wrote: 18 Apr 2023, 19:42 Im not kidding, i stress out because Im concerned it might overheat like the white one did, even though that was fan related, or like the more likely chance the 960 has in hot climates. But it worked good yesterday! Does anyone here have an elevated stress level about their Volvo failing in some way? Stress they dont have with their non-Volvo cars?
Every single day driving my old V70. I knew it had a bad head gasket patched with a head gasket sealer though. It was knowing there were things that i may need to fix but not having the time to fix it. I must say though, having CAA (AAA for americans) gave me a lot of peace of mind. They came when my rad froze on the highway and drove it to a place i could work on it.
On the anxiety levels i rank it as follows (low to high)
Exhaust
Suspension
Alternator/power steering
Fuel related
Cooling Systems
If you are really worried keep a spare fan in the trunk. Doesnt take too long to change one of them if you do suspect a failure.
2008 S60 2.5T Auto (Sold)
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
Replaced the driver seat controls yesterday, impressively easy to do
Now this morning the car wouldn't run properly (wont rev, almost stalling ) :shock: Is the seat control part of the engine management ? :lol:
...actually it's probably because I unplugged the battery, will troubleshoot tomorrow
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Don't think so. The only connection might of been the air-bag control, but that is not linked through the same part of the harness, and it would throw a code. Did you try switching the engine off and trying to restart it? If the issue goes away, it is likely your electrical part of your ignition switch is worn.
Been thanked: 4068 times
Decided I will do the valve job on Shagg.
In my new garage.
bmdubya1198
abscate wrote: 20 Apr 2023, 18:25 Decided I will do the valve job on Shagg.
In my new garage.
Don't pack it too full of Volvo parts to get the car inside!
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
INside?!
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
In my new garage.
Won't you overheat in your coveralls??? :D
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
