- Has thanked: 316 times
- Been thanked: 531 times
These will cause PTSD with cooling system issues... that's how a friend of mine was with his S60R lol.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I felt the same way. An all aluminum engine, coupled with a temp gauge that is a bit vague. So I mounted one of these Scan Gauge's.
I am able to watch the temp by degree, which has eased my mind considerably.
https://www.amazon.com/ScanGauge-Automo ... 61819&th=1
1999 V70 GLT
1999 V70 GLT
- Has thanked: 2209 times
I fixed the stress level by giving the R to my wife to drive!
Neil
Neil
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Every single day driving my old V70. I knew it had a bad head gasket patched with a head gasket sealer though. It was knowing there were things that i may need to fix but not having the time to fix it. I must say though, having CAA (AAA for americans) gave me a lot of peace of mind. They came when my rad froze on the highway and drove it to a place i could work on it.CIK7 wrote: 18 Apr 2023, 19:42 Im not kidding, i stress out because Im concerned it might overheat like the white one did, even though that was fan related, or like the more likely chance the 960 has in hot climates. But it worked good yesterday! Does anyone here have an elevated stress level about their Volvo failing in some way? Stress they dont have with their non-Volvo cars?
On the anxiety levels i rank it as follows (low to high)
Exhaust
Suspension
Alternator/power steering
Fuel related
Cooling Systems
If you are really worried keep a spare fan in the trunk. Doesnt take too long to change one of them if you do suspect a failure.
2008 S60 2.5T Auto (Sold)
- Goupil
- Year and Model: 98' V70 LPT
- Has thanked: 30 times
Replaced the driver seat controls yesterday, impressively easy to do
Now this morning the car wouldn't run properly (wont rev, almost stalling )
Is the seat control part of the engine management ?
...actually it's probably because I unplugged the battery, will troubleshoot tomorrow
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Don't think so. The only connection might of been the air-bag control, but that is not linked through the same part of the harness, and it would throw a code. Did you try switching the engine off and trying to restart it? If the issue goes away, it is likely your electrical part of your ignition switch is worn.
- Has thanked: 1611 times
- Been thanked: 4072 times
Decided I will do the valve job on Shagg.
In my new garage.
In my new garage.
Don't pack it too full of Volvo parts to get the car inside!
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Won't you overheat in your coveralls???
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
