850 sump splash guard
- Has thanked: 292 times
- Been thanked: 765 times
Re: 850 sump splash guard
Two of my P80 cars lost the air guide this winter, on the other it's nearing end of life, debating how many to replace.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1497 times
- Been thanked: 3810 times
If you can get Amazon to ship the URO one to you undamaged it is a decent replacement.
- Has thanked: 1836 times
- Been thanked: 1709 times
It is about the only URO part worth considering. Maybe purchasing multiples makes the shipping more durable?!?
454cid
- Year and Model: 1996 850
- Has thanked: 145 times
- Been thanked: 128 times
I was wondering about the URO. Thanks for mentioning it. That's likely what I'll do.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
It's missing on my 850.... the car came to me that way. I can see some paint work, so it's likely a bodyshop didn't put it back on. The S70 does have one, but it's loose. I noticed it hanging a bit low the other day. It may only be zip tied in place since the car was in a frontend accident before I got it, and much of the lower area in the front is secured that way. I hit something in the road a few weeks ago.... think it was maybe an already dead deer. I assume that impact is what loosened the air-guide.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
There is a small flimsy bracket, at the back upper edge of the air-guide that often gets broken in an impact. It can hold in place without it but not ideal. That flap goes into a small slot in the bottom of the radiator in the middle. I pop-rivet a small aluminum bracket to replace it. Downside is that as it is so much stronger, it could damage the bottom of the radiator on further impact. Check the 'legs' at the front edge are not broken off. They latch into the bumper to support it. If both supports are broken, the air-guide will vibrate and probably loosen the 2 10mm headed bolts (one each end).
I run a safety nylon line in mine so that if when the tabs break I don’t lose the beast
As is the norm in most P80 sales!
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
