Busted Strut Tower - 1993 850
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
I will try to take a photo tomorro morning
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- RickHaleParker
- Been thanked: 979 times
If that crack was fresh, the edge of the crack would be shiny metal.Volvebaker wrote: 29 Oct 2022, 14:41 It blew my tire, busted up the rim, and I thought bent my strut however, I now see that the bang was so hard it actually broke the strut tower away from the body.
From what I can see, it looks like its been cracked for some time.
Active
Past
Past
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 84 times
The ABS stuff looks like my '95, Here is how I did it. Also want to see what Clemens came up with
Though I am not sure if you are talking about the ABS control unit or just the connector? I had to move the connector and wire harness, but in your photo with the aftermarket bar it looks like it might not be high enough to clear the control module/computer. The volvo bar does fit over it. Don't think that you can relocate the computer easily.
download/file.php?mode=view&id=78836
850 T5-R '95 auto
- Clemens
Tomorrow morning turned into tonight.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Clemens
The key is to remove the module upper brace and use zipties instead. One year and a few track days later everything seems to be fine
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Volvebaker
- Year and Model: 1993 850 GLT
- Been thanked: 12 times
hausmeister wrote: 28 Jan 2023, 02:08 The ABS stuff looks like my '95, Here is how I did it. Also want to see what Clemens came up with
Thank you both much for sharing!! Looks like y’all both went similar routes of, well, re-routing.Clemens wrote: 28 Jan 2023, 12:34 The key is to remove the module upper brace and use zipties instead. One year and a few track days later everything seems to be fine
This makes me hopeful I can make mine work if I can get that tower pushed back over. I’m glad now that I didn’t return it, just yet.
s70t5ing
- Year and Model: S60 T5 M66
Looking at the first pic, it looks more cosmetic than structural.
The strut tower isn't broken, it separated from the seam, but if they looked underneath and there is no damage than it is cosmetic.
If you want to see how bad strut towers get, look at e36 and e46 strut towers that rust. Then you need a plate welded in.
They can bondo/caulk that area, and if you throw a strut brace on, it should help with the rigidity of the front towers.
1995 850 Turbo, 2005 S60 T5 M66, 2009 S60 2.5T AWD
- 22 Replies
- 4199 Views
Last post by ThommyKent
- 1498 Views
Last post by bmdubya1198
- 1193 Views
- 798 Views
Last post by darrylrobert
- 930 Views
Last post by misha
