Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
jamezcab wrote: 20 Apr 2023, 16:22 😂 my apologies this is a lab rat i ordered. obviously incorrect
Be a man and make it a CEM!
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
vtl wrote: 20 Apr 2023, 15:54 FYI, CAN transceiver in original schematics is EOL.
Replacement: SN65HVD230QDR
jamezcab
Year and Model: 2004 xc90
Post by jamezcab »
vtl wrote: 20 Apr 2023, 16:33
i know what your saying my friend 😂 but an xc90 is a large ornament if i brick cem 😅
green2man0
Year and Model: 2006 xc90
Post by green2man0 »
I'm in a similar spot. My power seats and cigarette lighter recently stopped working....both individual fuses are good and it seems to be a not uncommon issue related to a shared relay on the CEM.
https://modulerepairpro.com/products/05 ... cem-repair
I don't know how good they are but they are a lot cheaper price wise than Xemodex. I plan to try them out. I'm also doing valve cover gaskets (06 xc90 4.4) and waiting on a few more parts. Plan is to coordinate the best I can and have the CEM out for repair while doing valve cover gaskets and by the time the CEM is back to have the gaskets done.
myname
Year and Model: 2007 XC70
Been thanked: 4 times
Post by myname »
T5Luke wrote: 21 Mar 2023, 10:00 The "not so good" copied dice versions, seem to have probs with the send periodic msg function which is used for prog mode. I try to do a workaround later...
have you had a chance to look at this?
T5Luke
Post by T5Luke »
How does your dice appear in device manager?
dikidera
Year and Model: S60 2005
Has thanked: 68 times
Been thanked: 187 times
Post by dikidera »
Oddly enough I never needed to send any periodic msgs in my S60 P2 and my custom device, in programming mode. Once the modules were all "asleep" I could do anything I wanted and I observed no changes in the car.
myname
Post by myname »
it says DiCE Hardware -> DiCE-206751@000000000000
rkam
Year and Model: 14473_96090_XC7007
Has thanked: 5 times
Been thanked: 25 times
Post by rkam »
The J2534 periodic message function was used to ensure that the FF 86 commands was sent fast enough for all modules to enter programming mode. This way it is not limited by software, operating system or computer speed.
dikidera
Post by dikidera »
So it isn't just about sending the command and ensuring all modules have received it, it's about how fast it is sent? Is this why I got an SRS Airbag DTC?
My python code for RPI basically alternated between the buses and sent the FF 86 command for a second or two, spamming basically. This worked for me, but the SRS Airbag code got triggered and could not be easily cleared. Obviously python->socketcan->mcp2515->can bus is introducing a lot of latency.
As for knock off dice, some people have had no luck getting it to even work.
https://www.swedespeed.com/threads/conn ... st-8078413
Who is online
Users browsing this forum: Amazon [Bot] and 20 guests
