Vida CEM swapping
T5Luke
Year and Model: S60 T5 2001
Has thanked: 11 times
Been thanked: 130 times
Post by T5Luke »
The beginning looks good, but later something goes wrong, maybe power issue?
Copy the bytes into HXD and save as bin to get your file...
jamezcab
Year and Model: 2004 xc90
Post by jamezcab »
T5Luke wrote: 29 Apr 2023, 03:03 The beginning looks good, but later something goes wrong, maybe power issue?
ok thank you have been away now i have returned
i have re soldered power connection currently taking read now appears more complete
jamezcab
Post by jamezcab »
how is this? i stil cant make work with cem tool :cry:
vehicle is xc90 maybe parameters are different?
labrat cem .rar
(215.47 KiB) Downloaded 130 times
T5Luke
Post by T5Luke »
HXD uses left and right window, you need to paste the data into the left window for binary data, you pasted it into the right for ascii data...
From what i see the file looks good
jamezcab
Post by jamezcab »
T5Luke wrote: 29 Apr 2023, 14:17 HXD uses left and right window, you need to paste the data into the left window for binary data, you pasted it into the right for ascii data...
🤔 i dont know what why it done that was sure i just pasted it over the the binary window.
can you see pin in this data ok?
T5Luke
Post by T5Luke »
Your code should be: 23 42 90 61 52 76
Not the best read, some errors still but should work for this purpose...
Maybe to long wires or something...
You should just copy paste the binary data like this, you saved the txt file
jamezcab
Post by jamezcab »
:D :D
thanks luke its a thing of beauty
gmtgmt
Year and Model: Volvo 850 T5R
Post by gmtgmt »
Try to make a Genuien Dice to work with this UDStools, My dice nr is 202769 every time i try to change it, the program wont run afterwards.
T5Luke
Post by T5Luke »
You just need to overwrite 206751 delete nothing or add nothing, works best with HXD
gmtgmt
Post by gmtgmt »
T5Luke wrote: 30 Apr 2023, 11:04 You just need to overwrite 206751 delete nothing or add nothing, works best with HXD
Like this? Sorry Im a complete Noob to doing this stuff
Find the text with Dice and over wirte?
