Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
These exhaust heat shields prevent a lot of heat transfer from exhaust to other parts.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
I did read for coworker S60 fault codes. He had there Low air flow or restricted for MAF.. Couple days later i hear he went car wash and fault disappeared.
I am gonna write that down for that fault code for future people.
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
Got all the exhaust manifold bolts removed, all but 1 stud came out with the nuts. Now the coolant lone is giving me a lot of grief. How do I remove this lower bolt? I can get a 10mm box end wrench on but it's touching on both sides so you can't actually turn the wrench. Sockets will fit but the ratchet is too wide. I assume I cannot remove the head with this in place.
ZionXIX
Post by ZionXIX »
I wised up and tried a u joint adapter. Here's the result....
Into the next idea.
ZionXIX
Post by ZionXIX »
Well the good news is I got the 2nd bolt out. I had to chew the crap out of it with a 3/8 12pt since my 1/4 u joint bit decided to explode. I used a borescope to guide my socket placement and I could not get more than a 60 degree bite on this bolt head.
This was the barely winning combination.
I have no idea how I'm going to bolt this pipe back in place at the end.
Has thanked: 1613 times
Been thanked: 4078 times
Ah, the infamous water pipe M6 bolts. It’s much easier to put it in with the exhaust manifold off the car
Up the game to some Tektron sockets for that M6 , Pittsburghs and Kobalts are ok, but they will break on a tough application
Tektron, Matco, or snap on if you are loaded
You can get a straight shot on them with the right length extension. Use a six point to get a good fit
ZionXIX
Post by ZionXIX »
abscate wrote: 29 Apr 2023, 18:20 Ah, the infamous water pipe M6 bolts. It’s much easier to put it in with the exhaust manifold off the car
I have a set of tekton 6pt ratcheting flex head box end wrenches. I could not get them seat due the timing cover and no room to actually move them. I'm also trying to do this without removing the exhaust manifold. I tried the 6pt first but the u joint bit grenaded itself leaving me with only the 3/8 12pt as an option.
BlackBart
Has thanked: 967 times
Been thanked: 923 times
Post by BlackBart »
Could you replace it with a cap head bolt, with a recessed allen head? The tool should be much narrower and might fit in there.
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
Today from about 830am to 7pm (minus an hour) I spent my time tearing down engine/trans assembly from donor car. got down to block and crank. gotta take to auto place on monday to get the 29mm crank bolt out so i can get the crankcase off. 29mm socket stuck on it.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
ZionXIX wrote: 29 Apr 2023, 16:22 Got all the exhaust manifold bolts removed, all but 1 stud came out with the nuts. Now the coolant lone is giving me a lot of grief. How do I remove this lower bolt? I can get a 10mm box end wrench on but it's touching on both sides so you can't actually turn the wrench. Sockets will fit but the ratchet is too wide. I assume I cannot remove the head with this in place.
I wasn't able to remove the coolant tree without removing the exhaust manifold, due to the bolt closest to the drivers side in your pic.
As I recall it was tucked up behind the manifold.
1999 V70 GLT
