question on reusing bolts as part of rear caliper rebuild
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
Hi Folks,
I am in the process of rebuilding the rear calipers on my 99 s70.
These are the ATE fixed calipers. One piston on each side of caliper.
I split the calipers to thoroughly clean and paint the caliper halves. That is going well.
Each caliper is held together by 4 bolts. I went to a decent hardware store to source 8 new bolts and discovered ATE made a really odd decision back in the day that is causing me grief.
They chose an M7x45 bolt. I really wish they had chosen m8 or m6 as M7 is quite hard to source.
in M8, McMaster-Carr has literally has over 50 choices in head style, material, finish, etc that would be appropriate.
in M7, they have 1 and it's not even an exact replacement as it's fully threaded vs the partially threaded that was in the calipers.
So.. I was thinking about reusing the old bolts.
Anyone have opinions on reusing the old bolts?
The bolts in question are these:
I have found some older parts diagrams that list a number for those bolts but the sites don't list them for order (and don't show a volvo part number).
Current options for sourcing these that have found.
1) buy 100 for a decent price of $17 + shipping but they are bare steel so they will rust instantly
2) it turns out that modern XC40s apparently use a M7x45 bolt to hold down injectors or the fuel rail but they have a flange head (built in washer) that may not fit properly on my calipers.
I am sure the answers will be to keep looking and buy new bolts. I would have done that instantly if they were an M6 or M8 as they are everywhere.
Does anyone have a favorite source for odd bolt sizes?
Ugh.....
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Unless these bolts have a torque then turn spec for tightening, I would likely reuse the old bolts. Also, did you try OEM Volvo bolt sourcing?
Mcmaster-Carr is typically a good source for fasteners of various types. Also look at Fastenal.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
^ Agreed. Unless they are torque to yield, clean and reuse. I use a little thread lock as well.
1999 V70 GLT
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
Tangential question: What's the required torque for the bolts in question? I'm also curious about the torques for any front caliper bolts. I had mine powder coated but have yet to reassemble them. Thanks.
FireFox31
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
If the bolts are in good shape and can be cleaned effectively, I'd reuse them without any further thought.
Yes, I've heard that M7 is not common in the US. I have an old motorcycle that uses some M7. Thankfully in the case I needed to replace one, it was a through bolt, and I was able to simply use a high grade 1/4".
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1609 times
Been thanked: 4065 times
Din 931 partial thread m7 45 8.8 bolt…snap, ping , Belmetrics….
https://belmetric.com/m7x1-0-coarse-din ... BR7X45PCLZ
These bolts have to both hold the caliper halves together to seal, and also withstand 2x brake pressure over the pistons, every time you brake you are trying to stretch these with about 500 psi pressure.
Grade 8..8 is 8 MPa tensile strength or about 1200 psi, so 4 of them are safe up to 1000 psi working pressure , factor of 4x below tensile strength.
That’s a pre coffee calculation
Torque? I would use 20 Nm or 15 foot lbs
Oh yes, that internal o ring on the caliper halves was not available last I looked for it. Keep it safe!
No Volvo part number for those bolts. The calipers aren’t shown exploded in VIDA
M7 are used on the intake manifold and a couple of other places but I think those are all flanged
amblerman
Post by amblerman »
abscate wrote: 04 May 2023, 04:31 Oh yes, that internal o ring on the caliper halves was not available last I looked for it. Keep it safe!
Those orings were tough to find.
I found a source for the orings through a classic Porche site.
I will find that an post it here or in a new thread. When I took my brakes apart, the orings were still quite pliable and matched up to the new ones I got. I might have even found the link to the orings here or maybe on another volvo site.
amblerman
Post by amblerman »
abscate wrote: 04 May 2023, 04:07 Din 931 partial thread m7 45 8.8 bolt…snap, ping , Belmetrics….
I watched a video rebuilding similar vintage Porche calipers (also made by ATE I think . very similar design) and the person in the video quoted a final torque of 17 ft lbs. So your pre-coffee calculation was darn close :-)
Thanks for the link. I can't tell you how many sites I visited and failed. (or were now dead sites).
-A
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
Plus three or 4 on reusing what you have, if they're a bit crusty a soak in Evaporust should clean them up without aggression.
