Sunroof track arm
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
^ Yep. First it would do what you're describing, then it stopped retracting at all and just tilted. Then that stopped. I checked the motor and it worked perfectly, so I knew it was a track issue. Feeling around up in the track I could feel a piece of something, so out with the glass cassette and that's when I found the broken bits. It's nice that the glass comes out as easily as it does. 6 screws and it's out.
1999 V70 GLT
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Just discovered the same issue, front passenger's track arm sheared on my '99 V70 XC. Do we have any good instructions laying around for removing just the cassette if possible without having to pull the headliner out? In my case I may be able to get away with some Dremel and epoxy action as it's the pot metal portion that broke.
I noticed the front would close at random depths and wouldn't "stay put" as it used to.
Has thanked: 2199 times
Been thanked: 1852 times
Looking at the parts drawing, I don't see a way to remove much other than the glass without taking the cassette out which unfortunately means the headliner too.
If you go onto the Volvo OE parts sites with their parts layout you can see what I mean. Not great but you can see from this drawing from a 98 Volvo hard copy parts book:
Sunroof parts layout
Hope this helps.
