2006xc70 Two unrelated questions:
First- Headlight restore- I have all the equipment to restore my lenses, but what should I put on the lens after I have cleared all the fog away from them? How do I minimize return of the 'clouding'? My wife said that there is a clear film to apply on the lens, I have heard of waxes, etc.
Second: I use Mobil One for the past 10 years. Car has 116K miles. What is the Formula for high milage? Should I change over? Any feedback on Kirkland brand, can I switch over at that brand?
Headlamp lens restoration and Oil question- Two separate topics in one!
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
I don't feel that 116k is high mileage on a Volvo engine. I have asked this very thing and what I've learned is the high mileage oils merely swell up engine seals to reduce external leaks. I'd continue using a high quality oil you like.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
You need UV-resistant clear coat. Sylvania headlights restoration kit has one, but it is not very durable. I had to redo everything every 6 to 12 months when was driving a lot of miles.
- Has thanked: 2199 times
You can get a 2k clear coat for headlights that will last a long time. Most of the wipe over stuff does not last all that long.
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
I sanded my LR2 Headlight and used the 3M wipes
https://www.freel2.com/forum/topic39154.html
But I also purchased
https://www.amazon.com/dp/B01M4RVVX6?ps ... ct_details
Post some picture of your restoration
Good Luck
Paul
Good Luck
Paul
- 2407 Views
Last post by krhodes1
- 766 Views
Last post by vtl
- 1013 Views
Last post by E Showell
- 2232 Views
Last post by sleddriver
- 1861 Views
Last post by Winnebago
