Name that rusty part
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
It looks like it's made of the same crumbly plastic as the power cable for the ABS motor.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
Are these crumbled wiring connectors still available to purchase new? Without a new replacement, how could this plug be rehabilitated?
Sorry I forgot about this thread. 50 MVS points to jreed and scot850 for identifying that the first post was a heat shield. Specifically, it's the rectangular one above the center muffler. I've never seen metal so brittle in my life. I may replace it if I get a good used spare. It would require cutting the welded cat-to-muffler pipe and having a Bear River Convertersrepair flange installed so I could remove the muffler. Probably not worth it.
FireFox31
- FireFox31
Here's another one. What part is this which was so rusted in place that it required extreme measures to remove?
FireFox31
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
Exciting to have a new entry in the ongoing contest…
I am guessing that it is the pinch bolt at the base of the control arm that attaches to the wheel hub.
- FireFox31
A solution in record time. Good work. 50 more MVS points to jreed.
Specifically, it's the lower front of the four wheel hub bolts, perhaps taking the most road salt due to its position. That bolt was so rusted in place that even after hitting it with a blow torch for maybe five minutes and shaving the head to grip it with Vice Grips didn't help. Ultimately, I hammered my Irwin bolt extractor around its flange, cutting deep grooves into the bolt, enough to hold the extractor in place. Poor extractor must have gotten a little dull from the job but it gripped enough to break the bolt free. Perhaps I shouldn't blame the bolt head for rusting, but the middle of the shaft which looked quite corroded.
FireFox31
- FireFox31
I was working on Geronimo which means we've got another entry in Name That Rusty Part. Shockingly, this one doesn't have any rust! So, what is / was this?
FireFox31
- jreed
Dang, this is a tough one. Not sure exactly which part. Could you give us a "getting warmer..." type clue... Could it be the brass or bronze metal shell that a bearing fits into, such as on a blower motor?
- Been thanked: 4068 times
Almost the shape of a parking brake cable clip.....
- Has thanked: 987 times
- Been thanked: 1075 times
Hard to tell the size.
I think it is a wheel hub seal.
- Has thanked: 2203 times
+ 1 on that wheel hub seal. It certainly looks like a seal of some sort if that is not it!
- 4406 Views
Last post by 93Regina
- 1757 Views
Last post by oragex
- 713 Views
Last post by voom8
- 2358 Views
Last post by seanj
- 23 Replies
- 6341 Views
Last post by Phantomphixer
